- 01-18-2013, 01:25 PM
Thread Author #1
[INFO/WARN] 1/18/13 VZW Note 2 OTA
[INFO]As of right now the update is believed to be the fix for the exploit in the kernel of our devices and therefore is a major security fix for your devices. That being said... THIS OTA WILL BREAK ROOT IF YOU DOWNLOAD/INSTALL THE OTA WHILE ROOTED. If you want to keep your root status there are a couple of options that are listed below...
- Don't do the OTA and continue to ues the Exploit blocker.
- If you are unlocked/rooted flash Scotts kernel that has the exploit patched.
- Don't worry about it if you don't sideload apps.
- If you want the OTA, use Voodoo OTA rootkeeper to save root settings, perform OTA and then use Voodoo to reroot your device.
Simple as that.
[/INFO]
[GUIDE] Unlock Your Note 2 Bootloader! | [ROM] AOKP Jelly Bean for Verizon GS3
[GUIDE] VZW ROM Listing and Guide | [GUIDE] VZW Galaxy S3 Flashing Guide
[GUIDE]Freezing GS3 Bloat with Titanium Backup! | [GUIDE] Restore Back to Clean Factory Stock Updated 9/22
[GUIDE] [MODEMS] VZW SGS3 (SCH-i535) | [ROM] Official CM10 Nightlies on your GS3!Thanked by 4: - 01-18-2013, 01:57 PM #2
Re: [INFO/WARN] 1/18/13 VZW Note 2 OTA
To Kill update notice simply use your root. File manager and rename SDM.apk.
This can be found at directory path /system/app
For example:I renamed it to SDM.bak
Or you can freeze SDM.apk. using titanium backup aswell
From my Galaxy Note 2 via TapatalkLast edited by DroidXcon; 01-18-2013 at 06:07 PM.
Thanked by 3: - 01-18-2013, 04:51 PM #3
Sorry to ask - but I can't seem to find the answer to this. I understand that if you are rooted using the exploit and update, you will lose root. But I am updated using odin but still stock. Can I safely update? Will I lose root? TIA.
- 01-18-2013, 05:03 PM #4
- 01-18-2013, 05:14 PM
Thread Author #5
If you are rooted, no matter which way you rooted and staying stock (aka didn't flash any roms) you will lose root if you are going to run the OTA. That being said, you can use ODIN to go back to having root but that will bring you back to 4.1.1 considering it is a whole different image file and will rewrite you system.
[GUIDE] [MODEMS] VZW SGS3 (SCH-i535) | [ROM] Official CM10 Nightlies on your GS3! - 01-18-2013, 05:35 PM #6
- 01-18-2013, 05:42 PM #7
- 01-18-2013, 05:45 PM #8
Thanks for clearing that up.
- 01-18-2013, 05:50 PM #9
- 01-18-2013, 06:07 PM #10
- 01-20-2013, 01:29 PM
Thread Author #11
Update...
If you want to keep proper root avoid the OTA at all costs.
Just to ensure that you keep full and functioning root make sure that you avoid this OTA. The only way that you will be able to regain root would be to format back to factory default OS and reboot.
[GUIDE] [MODEMS] VZW SGS3 (SCH-i535) | [ROM] Official CM10 Nightlies on your GS3!Thanked by 2: - 01-26-2013, 03:51 PM #12
- 02-22-2013, 11:58 AM #13
Ridin' a Note 2 blast - 05-01-2013, 12:25 PM #14
I still can't get the OTA to take. I've temp unrooted with Voodoo, and I'm running the stock ROM. Any ideas?
Also, I have no path named /system, so cannot find the subfolder /system/apps. This business of needing to "defer" the OTA every 3 days is for the birds. - 05-01-2013, 01:03 PM #15
Oh believe me there is a /system folder or your phone would be kaput. Get ES File Explorer from Google Playstore and after opening it go 'Up' until your're at the "/" folder. Look on that page for the folder named System. Also you could use Titanium backup and freeze SDM.apk. You may need to spring for the pro version of Tibu to freeze.
Official VZW ICS OTA by end of the month?
By dj_sproe in forum Droid RAZRReplies: 18Last Post: 12-16-2011, 05:36 PM -
Need help getting off 2.3.13 back to OTA
By jaa55 in forum Motorola Droid XReplies: 5Last Post: 12-26-2010, 11:17 PM -
Motorola Backflip 13.77 update ota
By icc4p2 in forum Motorola BackflipReplies: 0Last Post: 07-07-2010, 07:53 PM -
By icc4p2 in forum General News & DiscussionReplies: 0Last Post: 07-07-2010, 07:53 PM
Reply
