Little Wifi Notification Trick - No Root Required.
I saw this in the DNA forum and tried it on my Note 2 and it appears to work.
To temporarily disable the persistent and annoying ongoing wifi notification, do the following:
Pull down notifications
Long press the wifi notification and the press on "App Info"
When the App Info screen appears select "Force Stop".
You're done and no more wifi notifications.......... until you reboot your phone. You will then have to do the process over again.
Better than nothing eh?
Re: Little Wifi Notification Trick - No Root Required.
Weird, this doesn't work for me.
Sorry Edge... I gave bad info... you want to Force Stop... not Disable (you cant just like you said) I have amended my original post.
This video is for the DNA, but it worked on my Note 2.
Fast forward to 1:10 to cut to the chase.
[Only registered and activated users can see links. Click Here To Register...]
Sweet! Worked! Thanks for the tip.
Just found out if you switch to a different wifi connection the notification comes back.
Sent from my SCH-I605 using Tapatalk 2
When I do it my clock widget and the clock in my notification bar quit working, Anybody else having g this problem?
Sent from my SCH-I605 using Android Central Forums
The "little trick" screwed me up and wasted many hours of my time troubleshooting my phone. read this before you decide to mess yours up also: [Only registered and activated users can see links. Click Here To Register...] notice my bolded response some ways down the thread, where I explain the cause of my clock problem!!
