- 01-21-2013, 09:56 AM
Thread Author #1
Little Wifi Notification Trick - No Root Required.
I saw this in the DNA forum and tried it on my Note 2 and it appears to work.
To temporarily disable the persistent and annoying ongoing wifi notification, do the following:
Pull down notifications
Long press the wifi notification and the press on "App Info"
When the App Info screen appears select "Force Stop".
You're done and no more wifi notifications.......... until you reboot your phone. You will then have to do the process over again.
Better than nothing eh?Last edited by kilofox; 01-21-2013 at 10:55 AM.
Thanked by 2: - 01-21-2013, 10:36 AM #2
- 01-21-2013, 10:53 AM
Thread Author #3
Re: Little Wifi Notification Trick - No Root Required.
- 01-21-2013, 11:32 AM #4
- 01-21-2013, 12:13 PM
Thread Author #5
Just found out if you switch to a different wifi connection the notification comes back.
Sent from my SCH-I605 using Tapatalk 2 - 01-31-2013, 05:27 PM #6
- 02-02-2013, 03:39 PM #7
The "little trick" screwed me up and wasted many hours of my time troubleshooting my phone. read this before you decide to mess yours up also: Time wrong in notification bar [SOLVED] notice my bolded response some ways down the thread, where I explain the cause of my clock problem!!
Samsung Note 2 and Nexus 7
[APP] Roam Control Optimus (NO ROOT REQUIRED)
By Nick7 in forum LG Optimus SReplies: 198Last Post: 02-16-2013, 07:39 AM -
Guide - How to change your PRL [no root required]
By gothir in forum HTC EVO 3DReplies: 21Last Post: 10-28-2012, 11:45 PM -
How to Flash ICS for WiFi Xoom NO ROOT REQUIRED
By harold42483 in forum Motorola XoomReplies: 116Last Post: 07-17-2012, 01:45 PM -
[HOW TO] eliminate lag in your phone (no root required)
By elucid in forum Verizon Droid ChargeReplies: 6Last Post: 06-17-2011, 01:39 PM -
Show Your Screenshots: No Root Required with EVO!
By ToNeDrOiD in forum HTC EVO 4GReplies: 3Last Post: 05-26-2010, 08:29 AM
Reply
