Results 1 to 6 of 6
    dt81's Avatar
    Posts
    Global Posts
    924 Global Posts
    Default Phone won't go into deep sleep with new battery
    using the this new 3500mah, my phone won't go into deep sleep.
    any reason this could be happening? and how to resolve?
    Phone won't go into deep sleep with new battery-uploadfromtaptalk1359294202058.jpg
  2. #2
    Battery won't effect deep sleep. There is something else that is running that is keeping your phone awake. Download GSAM Battery and that will give you a detailed breakdown of what's running and what's consuming your battery. My guess is a rogue app.
    Thanked by:
    dt81's Avatar
    Posts
    Global Posts
    924 Global Posts
    Default Re: Phone won't go into deep sleep with new battery
    But when I have my other battery in, it has no issues at all. I will download that app. Thanks
  4. #4
    It sounds strange yea, but the battery should have no effect on phone going into deep sleep since they battery does not control functions of the phone except for NFC. If you have an aftermarket battery (non-samsung) then it could possibly be problems with NFC. Most non OEM batteries don't support NFC so you should disable the feature in your settings. If you battery does support it then you should be okay. I am not saying this is your problem but its something to check into.
    Aside from that, the battery really has no effect on what you phone does or doesn't do, aside from the obvious power source. Let GSAM Battery Monitor run for a little bit and post a screen shot of what it says. If an app is running rogue than that should be close to the top if not the first thing that would appear on the list.
    Next question I should ask is are you running stock, or are you unlocked/rooted running a custom ROM?
    Thanked by:
    dt81
    dt81's Avatar
    Posts
    Global Posts
    924 Global Posts
    Thanks, will do. and I'm completely stock. I will run the app when the new battery goes back in and will watch what it does.
  6. #6
    esoh's Avatar
    Posts
    Global Posts
    141 Global Posts
    Were you able to get this solved. I'm the same way. I had to buy a new Samsung stock battery for my Sprint GNEX and as soon as it was installed, deep sleep is almost no more. And nothing has changed. When I install the old battery, I get Deep Sleep. I'm on a custom ROM (MMuzzy) too. I tried resetting batt stats, but no avail.
  1. Phone goes into deep sleep?
    By racerxe24 in forum Verizon Droid DNA
    Last Post: 12-21-2012, 12:46 AM
  2. HELP!! Phone won't go past LG screen!
    By bradmckee in forum LG Optimus S Rooting, ROMs, and Hacks
    Last Post: 09-05-2011, 09:50 PM
  3. HELP - Phone won't go into 3G or 4G after trying LTE switch.
    By RMTPhotography in forum Verizon Droid Charge
    Last Post: 07-28-2011, 10:50 PM
  4. HTC Evo won't go into sleep mode!
    By DeeBoy21 in forum HTC EVO 4G
    Last Post: 04-01-2011, 11:23 PM
  5. battery won't go into sleep mode (battery drain related)
    By vertcobra99 in forum Sprint Epic 4G
    Last Post: 01-06-2011, 01:20 AM
B
