1. Ed270's Avatar
    Does anyone know how to add a custom notification to list? Is it possible without root?
    It's a Phone, it's a Tablet, It's a Phablet
    01-29-2013 10:49 AM
  2. Scott Kenyon's Avatar
    Use root explorer to navigate to /system/media/audio/UI/
    in that folder three of the files are the Spen Ogg files (Pen_att_noti1 2 and 3).
    Whatever sounds you want to replace the stock sounds must be renamed and placed here.
    Rename one of the old files (pen_att_noti2.bak for example) then rename the new Ogg file to the original name of the one you renamed.
    Sent from my SAMSUNG-SGH-I317 using Android Central Forums
    Ed270 likes this.
    01-29-2013 10:59 AM
  3. Ed270's Avatar
    Thanks! I used to do something similar with my droid incredible for custom ringtones. Thanks for the help:thumbup::thumbup:
    01-29-2013 11:22 AM
  4. pool_shark's Avatar
    Doesn't that require root?
    01-29-2013 11:27 AM
  5. kris.richards's Avatar
    I'm pretty sure it does...
    01-29-2013 12:12 PM
  6. Ed270's Avatar
    Yep, root must be required it won't let me write to that file
    01-29-2013 01:29 PM
  7. dubge's Avatar
    These are the directions I followed - you have to be rooted
    [MOD] LightSaber S-Pen sounds - xda-developers
    here is a bunch of sounds
    [Mod] Custom S-Pen Att/Det Sounds - xda-developers
    enjoy
    Ed270 likes this.
    01-29-2013 01:42 PM
  8. Ed270's Avatar
    enjoy
    Thanks, I guess my reasons for rooting are growing . Custom s-pen sounds, Add any app to multi view,and using two different keyboards
    01-29-2013 01:52 PM
  9. Scott Kenyon's Avatar
    There's no reason not to root really. It's safe and lets you do all sorts of handy stuff you can't do out of the box.
    Ed270 likes this.
    01-29-2013 01:58 PM
  10. Ed270's Avatar
    Well I went ahead and rooted so now I have the s-pen "light sabre" I wanted as well as any app to multi view and keyboard switcher all is well thanks guys!
    Sent from my SCH-I605 using Android Central Forums
    01-31-2013 02:12 PM
  11. Speedmcs3's Avatar
    @Uribam, I have a Note2. Not rooted. I tried the root explorer, and found the .ogg files for the s pen, and tried to delete, rename, or move, and it said unable because they are read only files. Do I need to be rooted to replace sound files, like the droplet noise for selecting screen items?
    05-03-2013 11:52 PM
  1. screen disappears when detach the pen or attach the earphone
    By albertodelrio in forum AT&T Galaxy Note 2
    Last Post: 01-24-2013, 04:30 PM
  2. screen disappears when detach the pen or attach the earphone
    By albertodelrio in forum Samsung Galaxy Note 2
    Last Post: 01-24-2013, 08:26 AM
  3. How to Silence Start-Up sounds?
    By Macaquinho in forum HTC Hero
    Last Post: 10-05-2012, 02:02 AM
  4. Attaching sound issue
    By iler19 in forum Motorola Droid
    Last Post: 03-17-2011, 03:10 AM
  5. Droid Sound
    By Xxw0lfxX in forum HTC Droid Eris
    Last Post: 11-20-2009, 10:21 AM
