1. dt81's Avatar
    I've installed two games that I use very frequently through out the day.. And today it got really hot, GSAM BATTERY showed it was 98 degrees. how hot has ur phone gotten?
    02-06-2013 04:15 PM
  2. Jude526's Avatar
    My Note2 has never been higher than 84F. Never feels hot. My HTC devices always ran warmer!
    Sent from my Samsung Galaxy Note2
    02-06-2013 04:41 PM
  3. dt81's Avatar
    Hm, well I uninstalled the games and put them on my S3 so we shall see how that goes.
    02-06-2013 07:22 PM
  4. in8won's Avatar
    Mines 88 right now. There has been a few times it has felt hot but i didnt check the temp then.
    Sent from my SCH-I605 using Android Central Forums
    02-06-2013 08:16 PM
  5. ishore99's Avatar
    Not as hot as my previous phone the Droid Maxx.........
    02-07-2013 07:11 AM
  6. 1812dave's Avatar
    Not only has my N2 never gotten hot (including while playing AB), it never feels warm. I used to own a Star Tac. During phone calls that sucker got so hot it felt like it was literally going to burn my cheek. I couldn't hold it tightly to my face during lengthy phone calls. the heat from that phone was ridiculous.
    02-07-2013 12:51 PM
  7. anon(394005)'s Avatar
    Never felt any heat from mine even when streaming NFL games for three+ hours. My Thunderbolt though used to get quite warm (near 100F, sometimes a bit more). I think it has a lot to do with the Exynos quad core processors (more efficient) and the general size of the Note 2, larger surface area to spread any heat around.
    02-07-2013 01:07 PM
  8. MaxBuck's Avatar
    Overheating phone is a symptom of a short in the circuitry. I'd take it back for warranty service.
    02-07-2013 03:06 PM
  9. droidmyme's Avatar
    I wouldn't be so sure that GSAM battery has the accurate information - how is it measuring temperature and where?
    Sent from my LS670 using Android Central Forums
    02-07-2013 03:17 PM
  10. dt81's Avatar
    well, after un installing "are u smarter than a 5th grader" it has not gotten anywhere as hot as it did the other night. I installed the game on my S3 and played it and got real hot too. so I'm banking that the game just requires a lot of cpu usage causing the cpu to get hot. I hope.
    02-07-2013 08:46 PM
  11. ThisDieingDream1's Avatar
    Try charging your phone while being in the Belkin flip case with screen on its highest brightness for 3060 minutes.
    119.3f via battery solo widget.
    02-17-2013 12:49 AM
  12. roadpizza73's Avatar
    Short??? If u short a battery it goes up in smoke.
    Nibble by byte, weaning from google
    02-17-2013 12:57 AM
  13. dpham00's Avatar
    Are you talking about phones that have the similar class/type of processor like the DNA (which has the s4 pro cpu) or at least the same generation like the DInc 4glte (which has the dual core s4), or are you referring to an older generation cpu like the s3 in the Rezound or 2 generations older like the s2 in the thunderbolt?
    Sent from my Verizon Galaxy Note II
    02-17-2013 10:16 AM
  14. dpham00's Avatar
    It is more of a newer generation of cpu. My gs3 and note 2 get warm, maybe close to 100 F. The thunderbolt has a cpu that is 2 generations old. My thunderbolt got to 130F.
    02-17-2013 10:21 AM
  15. MaxBuck's Avatar
    Not really - unless it's a complete short to ground, in which case that could happen. But cold-solder joints and other manufacturing flaws can cause partial shorts that generate heat and reduce battery life.
    02-17-2013 11:33 AM
  16. jneusch's Avatar
    I've seen mine get to about 98 when plugged into the car charger, running a navigation app and the screen on 100% of the time. It cools down pretty quick once it's all shut down though. I attributed it to the lengthy screen time.
    Sent from my GT-N8013 using Android Central Forums
    02-17-2013 11:52 AM
  17. roadpizza73's Avatar
    A short is just that. Your "partial" short is a resistor.
    Electricity 101
    02-17-2013 01:24 PM
  18. bogart286's Avatar
    Recently I had full 4G service and decided to see just how much I could do with it. Activated tge HotSpot, connected my original Moto DroidX and started playing Netflix thru hdmi to my tv. At the same time I was downloading "Ted" in hd(1.44gb) and playing on YouTube. Suprisingly the data speed was great. Netflix never stopped to buffer. I have my battery widget set to alarm at 115 and it went off. That's when I disabled the HotSpot and got off YouTube until the movie finished downloading. Had my droidx up to 134 once. If I break 115, and I'm sure it will, I'll post it on here.
    Sent by Samsung Galaxy Note 2 from the inner depths of Hell!!
    03-06-2013 05:35 AM
  19. deadp1xel's Avatar
    Mine has been getting warm from using apps like Tumblr and robin
    Sent from my SCH-I605 using Tapatalk 2
    03-09-2013 09:01 PM
  20. viper31573's Avatar
    pretty much the only thing that raises the temp of mine is direct sun light(i live in FL). last week while waiting in the car for my father who was in a dr office, i had to turn on the ac a couple times and put my phone in the shade. i had it up to 105 briefly
    03-10-2013 10:26 PM
  21. S T Hye's Avatar
    Was at a friends house and my phone was very hot to the touch and losing battery power by the minute. She had very weak signal at her house. My phone has not done that before or after that episode.
    Tap-u-talkin from my Note Deuce
    03-10-2013 10:50 PM
  22. GregMargie's Avatar
    Haha Dave..... We're really aging ourselves but, my husband and I had the Star Tac
    phones too! We loved that phone and ours never got hot. It was a great phone at the time.
    I have not experienced my Note 2 getting hot at all.
    Margie
    Sent from my Galaxy Note 2
    03-12-2013 08:30 AM
  23. MaxBuck's Avatar
    Electricity 101
    You're absolutely right; a partial short is essentially a resistor. Now please discuss the Wheatstone bridge. Extra credit for describing any reactive elements to the circuitry.
    03-12-2013 10:10 PM
  1. Does this phone get hot?
    By Iceycold in forum Droid RAZR MAXX
    Last Post: 02-01-2012, 07:03 AM
  2. How hot does your AC adapter get?
    By PaulQ in forum Samsung Galaxy Tab 10-inch
    Last Post: 12-21-2011, 08:45 PM
  3. Does this phone get like EVERY update?
    By AllenRulz in forum Sprint Nexus S 4G
    Last Post: 08-21-2011, 08:02 PM
  4. How hot does your Thunderbolt get?
    By dpham00 in forum Verizon HTC Thunderbolt
    Last Post: 05-06-2011, 12:18 AM
  5. How Warm Does Your Shift Get?
    By Hest88 in forum HTC EVO Shift 4G
    Last Post: 02-13-2011, 06:36 PM
