Results 1 to 6 of 6
Like Tree2Likes
  • 2 Post By Jude526
    Default Major note 2 problem please help
    I Just got my note 2 saturday and the phone turns off for no reason. I was on the phone with my buddy yesterday and it just turned off, this has already happened about 6 times since I got it. Has anyone had this problem? Ive done a factory reset cleared the cache and rebooted the system and it still does it. Im bringing to verizon soon if I cant fix it. Keep in mind it turns off and doesnt turn back on I have to do it myself it isnt rebooting itself
    Sent from my SCH-I605 using Android Central Forums
  2. #2
    Default Re: Major note 2 problem please help
    Maybe a battery issue. Since you're within 30 days of purchase take it to Verizon and get the whole unit replaced on the spot for a new one.
    Sent from my SCH-I605 using Tapatalk 2
  3. #3
    Get it exchanged. You have 14 days. After that would be a certified refurbished. There is definitely something wrong with the device. Usually a factory reset will fix an issue. And when it doesn't ....get it replaced
    Sent from my Samsung Galaxy Note2
    sent from either my Samsung Galaxy Note2 or my
    Samsung Galaxy Tab 10.1
    Eclipse2K and collett like this.
  4. #4
    Quote Originally Posted by Jude526 View Post
    I could have sworn you had 30 days to return a device for the same item but 14 to return for a refund. Am I wrong?
    Edit: I think you're correct. Whoops.
  5. #5
    Not 30 days. They dropped that a long time ago. Its 14 days
  6. #6
    Depending on where you buy, you might have a longer return period, BUT, your contract is locked after 14 days (i. E. Return phone after 14 days and you are stuck with 2 years contract. I returned my Rezound twice after 14 days but within the 90 day Costco wireless return period, and both times received full retail box replacement. Return period varies depending on where you bought it.
    If you bought ut from somewhere that allows return after 14 days, you can get a full refund of the purchase price during the return period , but as said above, after 14 days, the 2 years contract is locked in.
    Sent from my Verizon Galaxy Note II
    "...Galaxy Tab 10.1, Tab 8.9 and Tab 7.7 do not infringe Apple’s Community registered design..." - Excerpt from Apple's website
  1. Major Evo problem...please help
    By Primetimeplaya in forum HTC EVO 4G
    Last Post: 04-02-2012, 10:45 AM
  2. Rooting Problem, Please help
    By nate3382 in forum Incredible Rooting, ROMs, and Hacks
    Last Post: 08-27-2010, 10:43 PM
  3. USB Problems, PLEASE HELP!!!
    By rob989_69 in forum AT&T Captivate
    Last Post: 07-25-2010, 08:53 PM
  4. Wi-Fi Problems! Please Help!
    By Basis in forum Motorola Droid
    Last Post: 07-16-2010, 10:37 PM
  5. since upgrade major problems please help
    By naenaek22 in forum HTC Droid Eris
    Last Post: 05-23-2010, 03:56 PM
