S pen is acting weird
jdtftp1
57
Just got my note 2 today. I slide the pen out and it's not touching the screen but if I move it by the screen the screen moves. I try to tap an icon and it is acting like I long pressed it to drag to delete. Any thoughts?
- - - Updated - - -
And it acts like it won't open apps by tapping on them
afeldsott
I had a bad S pen when my Note 2 was delivered. It acted like yours. I took my phone to the Verizon store, tried it with another S pen, and it worked fine. They tried changing some settings, but ended up having to replace my S pen.
cornettbr
127
You can always adjust the resistors if you Google it there are plenty of instructions online you just need a jewelers screw driver takes like 10 mins
Sent from my SCH-I605 using Tapatalk 2
