Results 1 to 12 of 12
- 02-15-2013, 08:10 PM
Thread Author #1
Galaxy Note 2 Battery life taking a HUGE dive...help!
I bought the phone back when Verizon released it in November. From November up until I updated the phone with the recent OS update (that fixes that Exynos bug)...I've had amazing battery life. I leave it on 4G, moderate use via texting...internet, phone, all that good stuff. I would charge it til 100 percent, take it off the charger at 6am, and when I'd get home at 6pm, I'd have like 80 percent on the battery. Recently, the battery life has been terrible. I take it off the charger, and after sending a few texts, getting on Facebook, Instagram here and there, it goes from 100 percent to 90...usually within 15 minutes of use. Usually, by 10am any day, I wouldn't be below 90 percent on my battery. Now, it's gotten down to 70 percent with light texting use by 10am. I barely get home with battery left on my phone. Instead of getting home with 80 percent, it's more like 30 or 40 percent. Sometimes even lower. I have no clue what's going on. Yesterday, I was just texting for like 5 minutes and was on FB, and my phone was getting hot, like if I was overusing it like crazy. I have no clue what's going on. What's draining the battery like this?
- 02-15-2013, 08:47 PM #2
Re: Galaxy Note 2 Battery life taking a HUGE dive...help!
Look at what apps are running. Could be one of them. And if you have a task killer uninstall it. Don't need on android devices....eats up battery life. Good luck.
I do know the update is causing battery issues with some people. Mine is OK.
Sent from my Samsung Galaxy Note2
sent from either my Samsung Galaxy Note2 or my
Samsung Galaxy Tab 10.1 - 02-15-2013, 08:51 PM #3
Been on 10.5 hours. Am at 68% I have been on it quite a bit today. Calls. Texting. Emails. Some days I use more. All depends
Samsung Galaxy Tab 10.1 - 02-15-2013, 09:35 PM #4
Did you try a factory data reset after the update?
Sent from my Verizon Galaxy Note II"...Galaxy Tab 10.1, Tab 8.9 and Tab 7.7 do not infringe Apple’s Community registered design..." - Excerpt from Apple's website - 02-15-2013, 09:39 PM #5
Also installing Better Battery Stats and GSM Battery monitor to find out what is using the battery, correcting it and then remove BBS and GSM, can help.
Sent from my AWESOME Note 2 - 02-15-2013, 09:56 PM #6
Bad battery? Shouldn't be getting hot on 5 minutes of use. Check for any signs of damage.
Also, do you constantly discharge until there is very little juice left?, Do you leave the battery in the charger for long periods of time after the battery is charged? Are you only using the original Samsung charger? - 02-15-2013, 10:11 PM #7
Actually leaving the phone on the charger after fully charged does not hurt the battery. I charge mine up while I am sleeping. Used to sell Verizon. It won't do damage. I dont recommend 3rd party batteries or chargers tho. They can cause problems
Samsung Galaxy Tab 10.1 - 02-15-2013, 10:28 PM
Thread Author #8
- 02-15-2013, 10:39 PM
Thread Author #9
- 02-16-2013, 08:55 AM #10
- 02-16-2013, 12:14 PM #11
The Note gets a little warm, which seems to be the processor and not the battery. What section of the phone is getting warm?
Sent from my AWESOME Note 2 - 02-16-2013, 12:26 PM #12
My personal preference is not to leave it on the charger after it is fully charged for the note 2 . It is not recommended to maintain a full charge for extended periods of time, it isn't good for the longevity of the battery. Some phones will charge to full then automatically discharge maybe 5% or so then recharge, continuing that cycle. The complaint that some people have is, how come it drops so fast, from 100 to 95% in such a short time.
Now, on the note 2, the phone remains at 100%, not following the charge discharge cycle i mentioned above, see the screen shot below.
I realize that a lot of people do what you do, and it certainly isn't gonna kill the battery overnight, but just saying that it is not ideal for the battery.
Samsung Galaxy S Battery Life Help
By Plinkfoyd in forum General Help and How ToReplies: 3Last Post: 05-17-2013, 08:05 PM -
Galaxy S3 & Galaxy note battery
By droid83 in forum Samsung Galaxy S3Replies: 4Last Post: 05-30-2012, 04:17 PM -
galaxy nexus battery life
By austinmueller99 in forum Verizon Galaxy NexusReplies: 18Last Post: 02-10-2012, 06:30 PM -
AT&T Galaxy Nexus - Battery Life?
By scottder in forum Google / Samsung Galaxy NexusReplies: 3Last Post: 12-19-2011, 09:07 PM -
Galaxy Tab Battery Life - Pretty Darn Good
By zmetl in forum Samsung Galaxy TabReplies: 0Last Post: 11-07-2010, 04:36 PM
Reply
