Results 1 to 3 of 3
    threepackape's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default is it possible to make the clock in the upper right hand corner display HH:MM:SS? (with the seconds)
    thanks!
  2. #2
    cornettbr's Avatar
    Posts
    Global Posts
    593 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    I'm sure if you root there would be a way
    Sent from my SCH-I605 using Tapatalk 2
  3. #3
    7711's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Quote Originally Posted by threepackape View Post
    thanks!
    There is an app called animated clock for the start page that can have a sweep hand which is accurate to about 2 seconds. It has an option to turn off the sweep hand because, unfortunately, it takes a lot of battery power to provide time to the second. You can have time in seconds, I don't know about the status bar, but it will cost you in battery power. The most accurate time is an app that displays time from the gps.
  1. Is it possible to make the Home Button a shutter button?
    By scribe4food in forum Verizon Galaxy Note 2
    Last Post: 12-07-2012, 03:23 PM
  2. Replies: 6
    Last Post: 11-12-2012, 04:33 PM
  3. is it possible to make the update notification go away?
    By ttlphotography in forum AT&T Galaxy S II
    Last Post: 01-17-2012, 12:25 PM
  4. Replies: 13
    Last Post: 09-09-2011, 12:49 PM
  5. Is it possible to make calls from GALAXY TAB
    By gary8988 in forum Samsung Galaxy Tab 10-inch
    Last Post: 08-21-2011, 01:08 AM
