1. GregMargie's Avatar
    So if I type an address, nothing happens? It won't go to the map and navigate. I can speak the address and it will go to the navigation. When I used this on my Thunderbolt both ways worked fine 'and' when you started to type an address a list of addresses would appear to just choose from.
    Are there known problems of the navigation not working properly on the Note 2?
    Margie
    Sent from my Galaxy Note 2
    02-17-2013 05:24 PM
  2. DroidXcon's Avatar
    Margie
    i have not had any issues with Nav, are vzw & google location services checked off? are you using data or wifi?
    GregMargie likes this.
    02-17-2013 05:27 PM
  3. Kelly Kearns's Avatar
    I typed the address and hit the search button on my keyboard and it asked if I wanted navigation or maps and worked fine.
    Sent from my AWESOME Note 2
    02-17-2013 05:46 PM
  4. GregMargie's Avatar
    Standalone GPS and Google are checked. The VZW one is not checked. I was afraid to check the VZW one thinking it was something they would charge extra for. So should all 3 be checked?
    Using data
    Margie
    02-17-2013 05:47 PM
  5. DroidXcon's Avatar
    Margie
    Yeah check all 3
    From my Galaxy Note 2 via Tapatalk
    02-17-2013 05:48 PM
  6. GregMargie's Avatar
    Mine doesn't give me the 'search button' to hit. Nothing changes when I typed in the address.
    Margie
    02-17-2013 05:51 PM
  7. Kelly Kearns's Avatar
    Margie
    Hmmm..I'm using Swype Beta, but when using Swype that came in the phone, my search button ( looks like a magnifying glass) would still show up at the right, anytime I was typing in a search field. What keyboard are you using?
    02-17-2013 05:54 PM
  8. Kelly Kearns's Avatar
    Just checked all my keyboards, they all have it bottom right near "return".
    02-17-2013 06:00 PM
  9. GregMargie's Avatar
    Ok I'm embarrassed! ! Duh, the 'search' button is in the keyboard, not at the top as it was on my Tbolt.
    I did check all 3 now in the settings. Strangely it did show a list of addresses as I typed in an address on my husband's Tbolt and now I can't duplicate that again.
    Thank you both!
    Margie
    Kelly Kearns and DroidXcon like this.
    02-17-2013 06:01 PM
  10. Kelly Kearns's Avatar
    Well I've had some apps show a search button at the top, but not all.
    Don't feel bad, I just figured out that search button was a search button a couple of weeks ago by accident.
    02-17-2013 06:05 PM
  11. GregMargie's Avatar
    Using stock keyboard....I see it now. Thank you!
    Margie
    02-17-2013 06:06 PM
  12. Kelly Kearns's Avatar
    Mine doesn't look up addresses as I type, but previous location are listed on the Navigation front page and there is a maps "button" on my contacts that I can click and it will pull up their address if I have one for them.
    02-17-2013 06:07 PM
  13. GregMargie's Avatar
    Yes that's what mine shows as well. When I couldn't get mine to work yesterday (appears that was operator error on my part) I took my husband's Thunderbolt and as I was typing an address at the top, down below it was updating with possible address matches that I could then just click on, and then the nav would start. It won't do it again now.
    Margie
    Kelly Kearns likes this.
    02-17-2013 06:20 PM
  14. Jude526's Avatar
    It is in Beta and there are weird things about it. I can type it and doesn't accept it. I can voice it and it accepts it but when I use the maps it takes it....go figure. On the Thunderbolt I never had this problem, but did this on my Rezound too. very weird......
    02-18-2013 06:39 PM
  15. DroidXcon's Avatar
    Thunderbolt was also a different Android build so I imagine not all things are equal. They may not catch every bug as things are constantly changing with every update of Android and maps itself
    02-18-2013 06:52 PM
  16. GregMargie's Avatar
    Kelly, thanks for your replies and for easying some of my embarassment! We all learn something new every day! I always tell my clients, No question is a dumb question, if you don't know the answer! So ask away!
    Margie
    02-18-2013 07:11 PM
  17. GregMargie's Avatar
    I agree.... "in beta" makes sense too. This is why we all love Android!
    Margie
    02-18-2013 07:16 PM
  18. DaRkL3AD3R's Avatar
    Is this what you're looking for? I just started typing a random made up address into Google Maps using their Search function and it is pulling up addresses that seem to match the typed in data.
    02-18-2013 09:43 PM
  19. GregMargie's Avatar
    http://img152.imageshack.us/img152/4...3021822413.png
    Thank you! Yes, that's it exactly! So based on what you just wrote.....
    I went to the 'Maps' icon, opened maps then hit 'Navigation' from that screen then started typing the address and the list of possible matches DOES come up.
    If I close it all out and go to the 'Navigation' icon First and type an address, the possible matches list does NOT come up. So it appears that you have to open the 'Map' icon and go to navigate from there on that screen! I don't really see a reason for the separate Navigation icon in the apps then.
    Thanks for your response.... so I know I can get that to work!
    Margie
    02-19-2013 08:49 AM
  1. Auto-Correct Doesn't Work on Email only (works on texts)
    By Sheepdogz in forum General Help and How To
    Last Post: 11-09-2012, 11:38 AM
  2. Replies: 13
    Last Post: 09-28-2012, 01:12 PM
  3. Car charging with navigation doesn't work?
    By StrifeSD in forum Google / Samsung Galaxy Nexus
    Last Post: 02-07-2012, 09:49 PM
  4. Replies: 0
    Last Post: 10-12-2011, 07:35 PM
  5. Netflix does not work correctly on my epic 4g
    By tomy2001 in forum Sprint Epic 4G
    Last Post: 07-23-2011, 11:13 PM
