Results 1 to 7 of 7
Like Tree2Likes
  • 1 Post By Wildo6882
  • 1 Post By MrMLK
    Wildo6882's Avatar
    Posts
    Global Posts
    2,287 Global Posts
    ROM
    Stockitty Stock Stock
    Default WidgetLocker Home Button Issue
    So I have WidgetLocker installed on my Note. No matter what setting I use, the home button unlocks the phone. Has anyone used this and had this same issue? If so, what did you do to fix it?
    Sent from my SCH-I605 using Tapatalk 2
    ejb1013 likes this.
  2. #2
    Default Re: WidgetLocker Home Button Issue
    1) Start the S-Voice App
    Apps->S-Voice
    2) Open the settings
    Menu->Settings
    3) Turn on "Open Via the Home Key".
    I don't know why this works (and I would personally prefer to disable S-Voice), but that makes Widgetlocker work.
    Thanked by 3:
  3. #3
    Quote Originally Posted by MrMLK View Post
    Apps->S-Voice
    Menu->Settings
    BRILLIANT!! I was struggling with this same issue and decided to try my hardest to just act like I never noticed it in the first place ... Now if you can tell me why widgetlockers widget overlap option refuses to work and how I can fix that I will crown you King of Widgetlocker ... lol
    Wildo6882's Avatar
    Posts
    Global Posts
    2,287 Global Posts
    ROM
    Wow! That's impressive! I had emailed the dev and looked everywhere. I thought I was just going to have to deal with it. Thanks again!
  5. #5
    No problem. I had the same problem three months ago and someone on some board told me what to do. I'm just paying it forward.
    Thanked by 2:
    Josphe72 likes this.
  6. #6
    loco90's Avatar
    Posts
    Global Posts
    49 Global Posts
    Apps->S-Voice
    Menu->Settings
    Thanks for the help on this. Now what do I do if I don't want S-Voice to open on the double click of the home button? Not a big, just wondering?
  7. #7
    Quote Originally Posted by loco90 View Post
    I wish I knew. Sorry.
  1. Lock screen problems and home button issue help!
    By ComedyBoy in forum Android 4.1 / 4.2 Jelly Bean
    Last Post: 12-21-2012, 09:16 PM
  2. Home button issue
    By aeph99 in forum Samsung Galaxy S3 I9300
    Last Post: 11-13-2012, 12:13 PM
  3. Home Button Issue w/Go Launcher
    By completestar in forum Sprint Galaxy S II Epic 4G Touch
    Last Post: 08-08-2012, 06:28 PM
  4. SIII Home Button Issue
    By TURBOSPARTAN in forum Samsung Galaxy S3
    Last Post: 07-09-2012, 09:42 AM
  5. Home Button issue
    By smailliwamed in forum Optimus V Rooting, ROMs, and Hacks
    Last Post: 07-08-2012, 10:09 PM
