It seems from time to time my phone will run a log from what I believe is Exynos abuse or superuser and will freeze whatever app I'm in till it finishes and I back out of it. Any idea why this is happening? I'm rooted stock rom.
try this, open super user, go to settings, go to default access, select [Prompt]It seems from time to time my phone will run a log from what I believe is Exynos abuse or superuser and will freeze whatever app I'm in till it finishes and I back out of it. Any idea why this is happening? I'm rooted stock rom.
what apps do you have in the apps section of SU
touch debuggerd and deny access if you can , or tell it to prompt youPrompt is there. I have debuggerd.exynosabuse, exynos abuse, root explorer, sqlite editor, and titanium backup in the apps. The first one is weird and I never saw that before.
I denied access. Hopefully that works. Phone has been great till this started and it only happens once in a while. Thanks a ton for the help as usual. I'll post how it works out.
