Terrible battery life?
anon(27512)
1,933
5
I have been getting very poor battery life. I took my phone off of the charger it came with today at 1pm. It is 6 pm now and my battery is at 39%
Today I have used path, some light messaging on Google+, and steamed like 6? Songs over bluetooth using rdio.
Not to be 'that guy' but I use my iphone 5 much more and it can last the day. I'm glad this isn't my only phone.
Is there a way to improve battery life outside of dimming the screen? I live in California so dimming the screen really isn't a solution with the amount of sunlight here.
Do you guys carry spare batteries? How do you handle it? Do I just have a bad battery?
Sent from my SCH-I605 using Tapatalk 2
gotta have it android
332
Could be the battery. Also having stuff to sync the second you get something (push) drains, leaving your screen to the highest all the time drains so you can try and set it to auto. turn things off you dont use all the time like S Beam and NFC, also GPS drains often
anon(27512)
1,933
5
I think it's the battery. It doesn't seem like other note users have this kind of drain. I usually have the screen at the half marker. And set to auto.
radgatt
1,690
15
38
I agree. I have had my phone off the charger for over 6 hours and I'm still at 81%. I would see if Verizon would be willing to switch the battery out without making you switch the phone.
Sent from my VZW Note 2 using Android Central Forums
Bond32
1,358
35
Install gsam from the market to see what's draining the most.
jdub1981
1,382
i need some pics. Make a screenshot of the home screen. Also go into settings..battery and show me a screenshot of that. Make a screen shot of application managers running apps.
There has only been a few time that my phone has acted in the way you describe. I thought there was something wrong with my phone as well...it ended up being an app that i thought i had closed but insted it just runs in the background. Not suspended but I actually closed it. It chewed through cpu time and in hour my battery used 30%. The whole time it did this the screen was off and in my pocket while in class.
Droid_Evo_8
799
42
I have terrible battery life. See pics below. :D
dpham00
Moderator Team VP
Moderator
Apr 23, 2011
30,108
200
63
What is the screen on time, and signal strength during that time? Gsam can show you the signal strength.
anon(27512)
1,933
5
Pulled the note off the charger at 1:30pm today. Here are my screens. Keep in mind that I haven't really used my phone today, and the only radio that is on is wifi. Screen brightness is below half with auto set.
This is my iPhone 5. Taken off the charger at the same time. I have bluetooth, wifi and GPS on and I've been using it. ImageUploadedByTapatalk1361756827.369127.jpg
Bond32
1,358
35
Don't know what you're trying to show. Those are just home screens, furthermore comparing to iPhone isn't useful. You need to get an app that will show you a break down of what is draining the battery. Again get gsam.
332
Was thinking the same on that. Heres my S3 with auto for the screen and semi good use
dpham00
Moderator Team VP
Moderator
Apr 23, 2011
30,108
200
63
Was trying to show the battery drain. Not sure how this app helps. View attachment 61386
Is that screen shot from after installing gsam and then doing a full charge,then start the discharge? If not, then do that. From the main screen. Press on the second button from the left on the bottom, that would show you temperature, phone signal, and radios.from the main screen, select app usage, it will tell you what each app used.
Goldchamp
102
This is my iPhone 5. Taken off the charger at the same time. I have bluetooth, wifi and GPS on and I've been using it. View attachment 61382
Well one thing turn the weather widget off. And it also look like alot of things are syncing.....
Nikoczzzz
