Results 1 to 6 of 6
    loco90's Avatar
    Posts
    Global Posts
    49 Global Posts
    Default Audiobook Help
    I like to check out audiobooks from the library and put them on my phone. When I had my iphone I was able to easily join the tracks together and it would remember where I stopped and play everything in order. I'm using Doubletwist to sync my itunes account, but the audiobooks aren't syncing correctly. I'm sure there is an easy way to do this. Any suggestions??
  2. #2
    MrSmith317's Avatar
    Mr Fix-It
    Posts
    ROM
    Stock Rooted
    Default Re: Audiobook Help
    Have you tried audible? It's already on the phone and it may work for what you're looking to do.
    “Around here, however, we don't look backwards for very long.
    We keep moving forward, opening up new doors and doing new things,
    because we're curious...and curiosity keeps leading us down new paths.”
    -Walt Disney
    loco90's Avatar
    Posts
    Global Posts
    49 Global Posts
    Quote Originally Posted by MrSmith317 View Post
    I do use Audible, but the ones from the library are free. If there was a way to sync them with my Audible account, that would be perfect.
  4. #4
    My library coordinates its lending through Overdrive Media Console. It allows you to download books as mp3 files as well as the WMA format used by iTunes. It lines up the chapters perfectly. Overdrive Media Console is available as an app on Google Play; it's free. I'd suggest checking with your library to see if they allow access to borrowed audiobooks using this method.
    loco90's Avatar
    Posts
    Global Posts
    49 Global Posts
    Quote Originally Posted by MaxBuck View Post
    Thank you, I forgot about that option. I still would like to try and figure out how to work with my existing audiobooks.
    loco90's Avatar
    Posts
    Global Posts
    49 Global Posts
    After doing a little research I found a nice little App that takes care of things for me. MortPlayer Audio Books works well for me.
  1. HELP! Need to get G1 Working or Dieter Will Kill Me!
    By Rene Ritchie in forum The Android Central Lounge
    Last Post: 05-19-2013, 08:19 PM
  2. My Turn - Help Dieter with the G1
    By Dieter Bohn in forum The Android Central Lounge
    Last Post: 04-26-2013, 07:08 AM
  3. HELP with my audiobooks and video files
    By jpinks in forum AT&T Captivate
    Last Post: 12-08-2010, 04:37 AM
  4. Round Robin: Help Jennifer with the G1!
    By gadgetgirl#ac in forum The Android Central Lounge
    Last Post: 12-14-2009, 08:59 PM
  5. SOS: Please Help: IMport SMS from XML file to G1
    By android007 in forum General Help and How To
    Last Post: 02-06-2009, 11:15 AM
