1. SHIVA77's Avatar
    As of two days ago, my Note II has shown an incredibly fast battery drain. I have not done anything new to the phone and no new Apps installed.
    It's a VZW Note II and still on 4.1.1. I got it the first day it become available on Nov 29 and it has been running stellar.
    I just checked the battery usage and it show Screen 37% and then Gallery 15% as the second highest user. Why is Gallery using power, when it's not even in use. I have removed the battery and now restarted and charging.
    Any insights would be appreciated.
    Cheers, S
    02-26-2013 04:09 PM
  2. 1812dave's Avatar
    i had a similar issue with Media (NOT Media server) draining the battery at a crazy-fast rate. I ended up (choke, choke) resetting the phone. It's been fine ever since. FWIW, the drain from Media was several percentage points every few minutes--clearly a serious drain. it's all back to normal and has been for quite some time. good luck.
    02-26-2013 04:40 PM
  3. SHIVA77's Avatar
    oh, I hope I don't have to reset. Thanks. Anyone else?
    02-26-2013 04:48 PM
  4. DroidXcon's Avatar
    You probably have it syncing with Picasa and if you don't have good data signal it may just keep trying and trying.
    From my Galaxy Note 2 via Tapatalk
    02-26-2013 04:57 PM
  5. SHIVA77's Avatar
    I thought so, I disabled Picasa Uploader and its still shows 15%. I tried that before posting.
    is there an app in particular I need to disable, besides?
    02-26-2013 05:07 PM
  6. DroidXcon's Avatar
    When did you disable it
    02-26-2013 05:31 PM
  7. SHIVA77's Avatar
    few hours ago and restarted. Gallery usage still 15%.
    02-26-2013 06:00 PM
  8. 1812dave's Avatar
    Battery stats don't reset until you get the battery back up to 100%
    Sent from Note 2
    02-26-2013 07:52 PM
  9. SHIVA77's Avatar
    and you are right...
    Now the Gallery is totally off my Battery usage list. and the massive draining seems to have stopped. keep in mind I disabled Picasa Uploader.
    02-26-2013 08:12 PM
  1. Battery life best... when not in use. ;-)
    By hannsoft in forum Verizon Droid DNA
    Last Post: 12-08-2012, 07:41 AM
  2. Replies: 21
    Last Post: 10-12-2012, 06:56 PM
  3. Maps using 15% of battery?
    By Mikey47 in forum HTC EVO 4G LTE
    Last Post: 07-27-2012, 11:32 AM
  4. Why is there so much battery drain when not in Use?
    By XChrisX in forum AT&T Galaxy S III
    Last Post: 07-18-2012, 11:59 PM
  5. Moment screen won't lock when not in use
    By ewells1014 in forum Samsung Moment
    Last Post: 10-16-2010, 04:56 PM
