1. johnnyshinta's Avatar
    I recsntly purchased a flip cover and have yet to decide if I like it. So I've been popping the stock battery door off and putting the flip cover on. And vice versa. Do I need to worry about the stock battery door breaking? I know it's plastic but is it really that brittle?
    03-23-2013 07:51 PM
  2. anon(394005)'s Avatar
    Since getting the phone back in Nov 2012, I've been taking the battery cover off every few days (sometimes more often depending on use) to swap out for a fresh battery and haven't had any problems. As long as you're careful taking it off and putting it back on it should be fine. Just don't flex it too much taking it off or force it back on if the clips aren't matching up right.
    03-23-2013 08:17 PM
  3. johnnyshinta's Avatar
    There were a couple of times that I wasn't as gentle as I should hae been but all in all I've been careful.
    And it doesn't show any signs of issue like warping or broken tabs.
    03-23-2013 08:25 PM
  4. anon(394005)'s Avatar
    Hey, worse case you can always get a new door!
    Titanium:
    From Verizon - Set Your Location
    From Samsung - Galaxy Note
    Marble White:
    03-23-2013 08:49 PM
  5. johnnyshinta's Avatar
    Oh thanks. That's very helpful. I think the back cover is fine for now and I don't plan to keep on removing it. But if something does happen I will just get a new one. Might just order one so it's around if I need it.
    03-23-2013 09:07 PM
  1. Verizon shipping free Droid battery doors?
    By Jeremy in forum Motorola Droid
    Last Post: 07-16-2010, 11:54 PM
  2. Replies: 6
    Last Post: 06-08-2010, 06:41 PM
  3. Creaky Battery Door?
    By tbdaly in forum Verizon Droid Incredible
    Last Post: 05-24-2010, 03:25 PM
  4. battery door question
    By cheeta186 in forum Motorola Droid
    Last Post: 01-08-2010, 04:08 PM
  5. FREE Droid Battery Doors - From Verizon
    By paa79594 in forum Motorola Droid
    Last Post: 01-04-2010, 12:05 PM
