Is the Verizon Note 2 model N7100 or SCH-I605?
Anyone know the answer?
It's the SCH - I605. If you go on your phone, Settings-About Phone, you will see on Model Number.
It is also on the name tag under the batteryIt's the SCH - I605. If you go on your phone, Settings-About Phone, you will see on Model Number.
Oh ok Thanks guys. Another question, anyone know if Verizon Note 2 support WCDMA, CDMA2000 or TD-SCDMA?
N7100 is the international model right
sent from Galaxy Note 2
Thanks for the quick replay talyorz, but i found another website call phone scoop said different. Source: Samsung Galaxy Note II (Verizon) Specs, Features (Phone Scoop) Anyone know which website is more reliable?
Ah nice, thanks for the information. Thanks a lot.
I read somewhere said it support EDGE network, is that true?
Sweet, thank you.
So as long as I make sure the phone support the foreign country's network, then root the phone, and change to correct apn setting, then I should be able to make/receive calls or texts, and use it's data correct?
