1. srmoreno's Avatar
    When I get home my wifi automatically turns on like it should, problem is the 4g stays active and confuses the phone which now thinks it has no data connection. On all my other phones including my s3 the 4G always goes dormant when wifi is connected. I end up having to turn off the mobile data tab to disconnect the 4G.
    Question is does anyone else's note 2 do this, or is it just my phone, or maybe there is a setting I missed.
    It becomes a problem because I can't receive mms while 4g is off and when I leave the house I forget to turn it back on and don't receive emails etc
    Thanks ahead of time
    Sent from my SCH-I605 using Tapatalk 2
    04-05-2013 09:49 AM
  2. GregMargie's Avatar
    When I turn wifi on 4G goes off.
    Margie
    Sent from my Galaxy Note 2
    04-05-2013 10:20 AM
  3. ishore's Avatar
    Whenever my phone goes into WiFi mode the 4G turns off by it self.
    04-06-2013 05:28 AM
  4. 1812dave's Avatar
    got two Note 2's here. they shut off 4G when connected to wifi.
    04-07-2013 11:57 AM
  5. gospodinjuha's Avatar
    I had this problem. I'm pretty sure it was an issue with my wifi and the n2 had to use 4g b/c wifi wasn't transferring packets to my phone. Router and phone reboot solved it.
    Sent from my SCH-I605 using Android Central Forums
    04-08-2013 02:27 AM
  6. TabGuy's Avatar
    I also had this problem. I pulled the battery on the phone AND reset my router. One of those two things fixed the problem as it hasn't occurred since.
    04-08-2013 01:09 PM
  1. Replies: 8
    Last Post: 08-05-2013, 10:24 PM
  2. Apps that turn off 4G radio and keep screen on while charging
    By inphoenix in forum Verizon Galaxy S III
    Last Post: 08-13-2012, 03:59 PM
  3. "Color of Wifi and Network Icons on AT&T"
    By ItsaRaid in forum HTC One X
    Last Post: 07-19-2012, 04:05 PM
  4. 4G vs Wifi and its effect on battery while idle-my test
    By dannyro77 in forum Verizon Galaxy Nexus
    Last Post: 04-23-2012, 05:12 PM
  5. 3G stays on while connected to Wifi
    By kilofoxtrot in forum Droid Bionic
    Last Post: 09-09-2011, 03:50 PM
