Results 1 to 19 of 19
Like Tree3Likes
  • 3 Post By solotristan88
  • 2 Post By pbuscemi
    cccgina1's Avatar
    Posts
    Global Posts
    9 Global Posts
    Default How do I stop the incoming call announcements?
    When I get a call lately, my phone says, incoming call from so-and-so. Nice and loud. incoming text too. Where do I turn that off?
    Thanks!
  2. #2
    Default Re: How do I stop the incoming call announcements?
    Quote Originally Posted by cccgina1 View Post
    Thanks!
    Change your ringtone for incoming calls to a ringer type instead of the announcement under phone calls where you can choose a new ringtone. Same with text messages.
  3. #3
    Simple! Pull down notification bar and unclick the driving mode. It will stop.
    1812dave, 808TBolt and Cluso like this.
  4. #4
    What if driving mode is off and it still makes announcements?
  5. #5
    Try going into settings and accessibility and see if talk back is on that may help
    Sent from my SCH-I605 using Android Central Forums
  6. #6
    Press phone to show the dialer
    in the upper right corner press the three vertical dots below "favorites"
    select "settings"
    select "caller id readout"
    select "ring only"
    Sgallion1 and jbird55 like this.
  7. #7
    Mine is set the way you suggested, but it still announces.
  8. #8
    Quote Originally Posted by Kelly Paridy View Post
    did you pull down the notification bar and make sure driving mode is NOT selected? that's usually the culprit.
  9. #9
    I press the phone and there is no 3 dots, only shows keypade logs favorites and contacts on the top!!!!!!!!!! It's not on driving mode went into setting accessibility and talk back is off I am going crazy and don't know what to do.
  10. #10
    On my Verizon phone there is an app called "Caller Name ID" that can't be uninstalled. But I went in and disabled it, and it finally stopped the name announcing.
    What a nuisance!
  11. #11
    I had the same problem with unwanted caller announcement. when it happened last ihut the button to show all open apps and the culprit seemed to be Motorola Assist (I have a Moto X). maybe it got stuck on driving mode. I manually closed the app and hopefully that will solve it.
  12. #12
    Go to Setting and then select APPS. Make sure you are under ALL APPS. Look for the one called Moto Assist Talk to Me and disable.
    You can still take advantage of the Moto Assist APP for when you are driving only without having to deal with this annoying feature on non-stop. Disabling the Caller ID APP did nothing to resolve this issue.
    Ooops....correction..you cannot use the Moto Assist APP....I just read this issue is a known bug where the phone once it activates the APP when you are driving doesn't revert back...so until a fix is identified, as mentioned before it can be disabled but the functionality is lost
  13. #13
    Disable talk back feature in settings
    sent from Galaxy Note 2
  14. #14
    Disabling Driving Mode in pull-down notification screen solved the problem for me. Thank you!
  15. #15
    assuming driving mode is off for Galaxy s5 go to settings... accessibility... voice control... uncheck the voice control option
  16. #16
    I've done all these things...car mode is off. Text to speech is off. On my s5, its so very loud. Make it go away?
  17. #17
    All,
    Go to settings, accessibility, answering and ending calls then make sure you un-check voice control.
  18. #18
    Thumbs up Re: How do I stop the incoming call announcements?
    THANKS!
  19. #19
    I found it and I could not find any of the answers here that were applicable. Go to settings, go down to 'apps' and then go down to 'talkback' and do a force stop. It took me forever to figure this out and I got no answers from googling it that worked.
  1. How do I stop the VIBRATE???
    By Jesse@AirLift in forum HTC Droid Eris
    Last Post: 10-18-2013, 12:24 AM
  2. How do i stop the GB update notification??!!!!!!!!
    By zrxoa1 in forum Verizon Droid Incredible
    Last Post: 11-22-2011, 09:07 AM
  3. How do I stop the "BEEP" when I end a call?
    By flashpiti in forum Verizon HTC Thunderbolt
    Last Post: 03-20-2011, 05:55 PM
  4. from FREE...How do i stop the text?
    By superglu3 in forum General Help and How To
    Last Post: 10-13-2010, 04:31 PM
  5. Replies: 9
    Last Post: 12-02-2009, 05:00 PM
