1. jweimn's Avatar
    So ive noticed that these last few days the battery life is not as good as it use to be and the phone was warm just idling and not doing anything. Im sure that it is probably a battery drain issue and I downloaded this battery drain analyzer app and it keeps coming up with android os is using a high amount of the battery. I didnt download any new apps since so im not sure what it could be. Trying to see what you guys think and point me in the right direction id like to avoid doing a factory reset.
    Thanks
    Sent from my SCH-I605 using Tapatalk 4 Beta
    06-07-2013 04:24 PM
  2. Shimmy00's Avatar
    Pics or it didn't happen.
    06-07-2013 04:38 PM
  3. jweimn's Avatar
    Here it is
    HiPower likes this.
    06-07-2013 05:19 PM
  4. Shimmy00's Avatar
    Download "Wake Lock Detector." Fully charge your phone. Check the App. at the end of your day.
    06-07-2013 08:23 PM
  5. jweimn's Avatar
    Thanks ill give it a try
    06-07-2013 11:23 PM
  6. geoff5093's Avatar
    Well for one it looks like you have a ton of apps running in the background as your notification bar is almost full, do you really need 3 different notifications for battery?
    06-11-2013 09:26 AM
  1. Horrible battery drain! Please help
    By jason6677 in forum Samsung Galaxy Note 2
    Last Post: 04-27-2013, 12:04 PM
  2. help with battery drain on das bamf 1.6.3
    By tboltuser in forum Thunderbolt Rooting, ROMs, and Hacks
    Last Post: 06-04-2011, 06:23 PM
  3. Battery Drain Help
    By Nytom30 in forum Verizon Fascinate Rooting, ROMs, and Hacks
    Last Post: 12-30-2010, 11:21 PM
  4. Help with SkyRaider 3.3.4 Sense Battery Drain
    By hcole623 in forum Incredible Rooting, ROMs, and Hacks
    Last Post: 12-06-2010, 09:52 PM
  5. battery draining very bad please help!!!!
    By kingwhite90 in forum Verizon Fascinate
    Last Post: 10-22-2010, 11:01 AM
