View Poll Results: Does PDANet+ (FoxFi) hotspot work?
Voters
6. You may not vote on this poll
  • Yes
    6 100.00%
  • No
    0 0%
  1. Super Turtleman's Avatar
    I'm seriously thinking about getting a Note 2. However, being able to tether from it via hotspot is a MUST for me. I prefer not to root so does PDANet+ work for you? Are you able to connect your laptop or tablet wirelessly to the internet via your Note 2? There is a poll above. Please vote and if you have any commments, post away. Thanks.
    06-15-2013 11:53 AM
  2. srkmagnus's Avatar
    I have a co-worker with the Note 2 and he said that FoxFi does work for him. Keep in mind that although it works today, it could be disabled and not work in the future. So i would highly caution purchasing the Note 2 on this condition.
    06-15-2013 11:56 AM
  3. GregMargie's Avatar
    I agree, as apps and products change quite often and different Carriers change policies and block things as well. I am on Verizon. With that said, I purchased PdaNet a couple years ago for 15.99 and had to connect USB cord between phone and laptop, and it worked very well. When I got my Note 2 in Feb. of this year, I couldn't get it to work and contacted June Fabrics (dev) and I had to just do an update as they combined (what I was told) with Foxfi.
    It worked great and now it is also wireless and I do not need to connect via USB/cord! So I am very happy. I truly hope that you don't make that a condition for NOT purchasing the Note 2, as it is the Best Phone I have ever Owned! Good Luck in your decision!
    06-15-2013 12:29 PM
  4. dpham00's Avatar
    The stock app works just fine without subscription, when activated by a third party widget
    Sent from my Verizon Samsung Galaxy Note II
    06-15-2013 01:46 PM
  5. snowwy66's Avatar
    the stock app works just fine. and it's included in the subscription.
    06-16-2013 08:15 AM
  6. jweimn's Avatar
    I use the stock app all the time with no issues. Only reason I'm clinging onto unlimited data
    Sent from my Nexus 10 using Tapatalk 4 Beta
    06-16-2013 01:24 PM
  7. karsdroid's Avatar
    foxfi.....no need for pdanet.....i've used both and foxfi is awesome!!!!!
    06-16-2013 10:16 PM
  8. Casey Cheung's Avatar
    Yes, works for my Note 2 by Verizon. Awhile back, I purchased the FoxFi app for about $8.00. The FoxFi app worked fine for my phone for doing wireless tethering un-rooted. Then later, there was an update (or message) saying essentially that I pretty much need to also download/install the PdaNet+ app (at not cost since I had previously already paid for FoxFi). I now have both the FoxFi app and PdaNet+ app installed on my phone. I used to open the FoxFi app for tethering, but now I simply click on the PdaNet+ app instead for tethering. The whole relationship between FoxFi and PdaNet+ has become a bit confusing in the past few months after FoxFi got bought out by PdaNet+ (I think), especially when app updates change the way the apps operate. Sometimes I get an error message saying I must pay for the mobile wifi hotspot feature, but after clicking out of the message, it goes away. I don't use the app too often, only when I'm out and about on the road. But it sure comes in handy!
    I also previously used the USB corded method for PdaNet back in the days of the Palm Treo smartphones. But I found the USB corded method to be a bit cumbersome because you had to install the PdaNet app both to the phone as well as the (Windows) computer that you will be tethering the phone too. Sometimes it was a b!tch to install the app to either phone or the laptop comptuer, because whatever additional app was required wouldn't be compatible with whatever device. I would then do a Google search to find whatever patch was needed for a particular phone to make USB tethering work. That was a pain! Not to mention that you could only tether via USB cable to 1 device at a time, whereas with wireless tethering, you can wirelessly tether to multiple devices simultaneously. Wireless tethering is superior to USB tethering in so many ways.
    06-17-2013 12:32 PM
  9. mysticalmalissa's Avatar
    Yes, it works with no problems for me.
    06-17-2013 01:22 PM
  10. karsdroid's Avatar
    There's no need for the pdanet with the foxfi. i also started getting those notifications about adding pdanet to foxfi but i ignored them. pdanet was great when that was the only option, but foxfi is in a whole different league. bag the pdanet, you don't need it.
    06-19-2013 05:47 PM
  11. Super Turtleman's Avatar
    Thanks for the feedback everyone.
    06-20-2013 05:13 AM
  1. Foxfi working on the Note 2?
    By Rednaz05 in forum AT&T Galaxy Note 2
    Last Post: 01-04-2014, 08:43 AM
  2. Does Pandora work on your WiFi Xoom?
    By inphoenix in forum Motorola Xoom
    Last Post: 04-07-2011, 03:51 PM
  3. Does Swift key work on Epic 4g
    By marisdaman in forum Sprint Epic 4G
    Last Post: 09-23-2010, 01:40 PM
  4. Does Vignette run well on your Captivate?
    By braj in forum AT&T Captivate
    Last Post: 09-07-2010, 02:54 PM
  5. How does Google Voice work on the Inc?
    By rayyork in forum Verizon Droid Incredible
    Last Post: 06-11-2010, 12:47 PM
