So I have noticed that on my Note 2 that my battery was draining alot faster than it normally would so I downloaded a battery drain app and figured out that it was the Android OS that was causing an alot of battery drain that what it normally does. I was able to pinpoint it to Google Maps being the issue and when I clear the app data it seems to fix the issue as my battery life goes back to being great.
I was wondering if anyone else experienced this? Or does anyone know of a good way to permanently fix this without wiping my entire phone?
Also would uninstalling all of the Google maps updates and then re-updating the app fix the issue and allow me to continue to use Google maps without the battery drain as I do really like maps but I don't want to have to be at the point where my phone is needing to be charged in 8-10 hours instead of the 16 or more I always use to get before this issue.
Any help is appreciated!
Thanks again!
Sent from my Nexus 10 using Tapatalk 4 Beta
Thanks again!
