What do you mean by screen on time? I'm at 46% right now when checking my battery level. I will try disabling some of those apps like you mentioned. Is that the same as uninstalling updates? Because that is the only option I have.
Under battery, tap on screen and it will display this screen...
http://img.tapatalk.com/d/13/07/01/ru9e9u4e.jpg
What?! ... I'm msndrstood.
via Note II
People lie about battery life.. People used to lie and tell me that the palm pre got 24 hours of battery life.. Lol
Sent from my SPH-L900 using Tapatalk 2
It didn't? Lol my Pre+ got 4-5 hours Max! If I didn't have 5 touchstones strategically placed at my house and work, I would have been screwed lol. But I do miss webOS though. Anyway, my Note 2 gets pretty great battery life! I can get through a 12 hour shift at work and have 20 percent still left with moderate use.
Sent from my SCH-I605 using Tapatalk 2
What's your screen on time after a day's use?
Seems like the Note should last longer than that. There could also be the possibility of apps that have been updated since you've switched over that are using more battery juice. The new Google Music app continues to run in the background and use up more juice than the previous version. After my one month free trial is up, I might cancel my subscription and downgrade back to the old version. I also disabled some of the Samsung media share apps I wasn't using that kept running in the background.
I have disabled many apps and bloat and it seemed to work. I'm getting somewhat better battery life, thanks.
