1. npharper's Avatar
    I recently bought an aluminum case for my Note 2, and it interferes with the LTE/CDMA signal. I was thinking of modifying the case by drilling a hole through the backing near the antenna(s), but I have been unable to find any information online about where inside the phone these antennas are located. I tried chatting with a Samsung representative, but they were unable to provide the information because they only know about the software side of things. I figured that the vast knowledge base of the members in this forum would be a good place to try.
    Does anybody know where these antennas are located? I would be happy to post a write-up on my project and the results if somebody would be so kind as to help me out.
    Thanks in advance.
    09-24-2013 05:29 PM
  2. dpham00's Avatar
    Not sure why Samsung can't help you, it was in their fcc filing, which is public record. Here it is.
    Sent from my Verizon Samsung Galaxy Note II via Tapatalk 4
    Attached Thumbnails Location of LTE/CDMA antennas-uploadfromtaptalk1380116352159.jpg
    09-25-2013 08:39 AM
  3. dpham00's Avatar
    NFC as well if you need it.
    Attached Thumbnails Location of LTE/CDMA antennas-uploadfromtaptalk1380116481629.jpg
    09-25-2013 08:41 AM
  4. anon(394005)'s Avatar
    Gonna need a bunch of holes/cutouts in that aluminum case. I'd be really curious to see if things still work properly even with all the appropriate holes.
    09-25-2013 08:49 AM
  5. dpham00's Avatar
    Interior photo
    Attached Thumbnails Location of LTE/CDMA antennas-uploadfromtaptalk1380117371029.jpg
    09-25-2013 08:56 AM
  6. npharper's Avatar
    Thanks for all the info. That was really quick. I see from the diagrams that there are multiple LTE antennas. Are these for the various carriers, or does the phone use multiple antennas to connect to Verizon's network?
    09-25-2013 11:15 AM
  7. dpham00's Avatar
    Both lte antennas are for verizon. One is rx/tx, one is rx only. It only supports Verizon 4GLTE (no other carriers 4GLTE is supported )
    09-25-2013 01:34 PM
  8. npharper's Avatar
    Okay, two more questions:
    1. Does Verizon use both CDMA antennas, too?
    2. In the diagram above, am I looking at the phone form the back, or the front?
    Thanks again.
    09-25-2013 05:38 PM
  9. npharper's Avatar
    Whoops, scratch that second question. It's right on the picture.
    09-25-2013 05:55 PM
  10. npharper's Avatar
    I did it. It works, but isn't pretty. I skipped the second CDMA antenna because I'm on 4G anyway, and got good enough results by drilling for those antennas.
    Here's the thread: Modifying aluminum case to improve signal
    09-25-2013 07:56 PM
  1. Replies: 5
    Last Post: 06-02-2015, 09:38 PM
  2. I'm so jealous of all you people with working Moto X's
    By tomatosouplabs in forum Moto X (2013)
    Last Post: 09-28-2013, 08:13 AM
  3. what versio of android are you guys on?
    By lopey986 in forum AT&T HTC One
    Last Post: 09-24-2013, 11:21 PM
  4. [app] Thought Of The Day [ NEW and FREE ]
    By Rachit Tech in forum Android Apps
    Last Post: 09-24-2013, 11:07 PM
  5. LG G2 not staying on LTE
    By mackie99 in forum T-Mobile LG G2
    Last Post: 09-24-2013, 06:45 PM
