I bought the following from Ebay about a month ago:
New Universal Qi Wireless Charging Receiver for All Micro USB Phone Samsung HTC | eBay
It is an excellent way to add wireless charging to the Verizon Note II, because it doesn't require any modding. It connects to the USB port on the phone, and if you use an external case, you don't even need to open the phone at all. Just position it between the back of the phone and the external case. Of course, you won't be able to use the USB port for anything else, but there are plenty of methods for transferring files wirelessly, which is about the only other thing I'd ever use the USB port for.
If you don't have a charging pad, you'll have to buy a QI-compatible pad. There are a ton of choices out there, though. This is the one I use; it's great except that it isn't silent:
Amazon.com: Koolpad Qi Wireless Charger Pad for All Qi Compatible Devices Including Samsung Phones with Receivers (White): Cell Phones & Accessories
