1. elvisgp's Avatar
    So, I rooted my note 2 and loaded Carbon custom rom onto it. But, a few days a ago my phone fell out of my pocket while getting into my car and now my phone won't connect to wifi. It still won't connect after multiple reboots, so it must be some hardware issue. I was going to go to Verizon to get a replacement, but I'm not sure if they will replace it since I rooted it. What should I do? Load a touchwiz rom onto it? Do you guys think they will notice that it is rooted? Thanks.
    12-23-2013 08:25 PM
  2. bigguy_132's Avatar
    Well couple of things you can do. I have rooted phones before and just restored them to stock and unrooted and it was never an issue. With the new counters that can show if you have rooted or not would be my only worry. If your tripped that and they checked it, that could lead to an issue.
    Samsung KNOX Counter you should know | Kingo Android Root
    Edit: Also are you claiming insurance or trying to get Verizon to give you a replacement through warranty? With insurance it isn't going to matter but with warranty it will.
    12-23-2013 08:35 PM
  3. elvisgp's Avatar
    I believe it's through warranty.
    12-23-2013 08:57 PM
  4. elvisgp's Avatar
    Do you think I could just flash a touch wiz ROM and they wouldn't notice?
    12-23-2013 09:10 PM
  5. bigguy_132's Avatar
    They may not but your best best would be to flash stock and take it in. And also check the KNOX status to make sure it hasn't been tripped. It's hard to say.
    12-23-2013 09:27 PM
  6. viper31573's Avatar
    You could Odin back to stock. There is also an app that cost a couple dollars that would reset counter. That is assuming you haven't taken the ota which I'm guessing you didn't
    Sent from my SCH-I605 using Tapatalk
    12-25-2013 07:57 PM
  1. Rooted, Now what?
    By munnin42 in forum Verizon Galaxy Nexus Rooting, ROM's, and Hack's
    Last Post: 02-07-2014, 03:34 PM
  2. Note 3 decline in battery life
    By Jnorton2724 in forum Samsung Galaxy Note 3
    Last Post: 12-26-2013, 06:31 PM
  3. MINT Verizon Galaxy Note 2 With TONS Of Extras
    By thatotherdude24 in forum Marketplace Archive
    Last Post: 12-26-2013, 04:51 PM
  4. Note 3 - Is It Really A Global Phone
    By Chelovek in forum Verizon Samsung Galaxy Note 3
    Last Post: 12-24-2013, 12:29 PM
  5. getting closer to the moment of rooting (casual). one question
    By 1812dave in forum Verizon Galaxy Note 2 Rooting, ROMs, & Hacks
    Last Post: 12-23-2013, 02:18 PM
