Results 1 to 7 of 7
    Default "Your device doesn't have enough storage space to synch." - Low memory error msg
    My stock un-rooted Verizon Samsung Note 2 phone went down to a pathetic 271 MB of available internal storage space. As a result, the phone couldn't do even simple things as synching my Gmail email account. There are probably other things the phone can't do as well due to running low on internal storage space.
    This is the first time I've seen this message. Even a new icon showed up in the top left corner of the screen. It's the white color circular icon in between 2 other icons. That's the icon warning me of low available space. See attached screenshot picture.
    Am I the first to encounter this problem? Am I the all-time low memory leader? Do I get a prize????
    Attached Thumbnails Attached Thumbnails "Your device doesn't have enough storage space to synch." - Low memory error msg-screenshot-low-memory-samsung-note-2.png
  2. #2
    Default Re: "Your device doesn't have enough storage space to synch." - Low memory error msg
    Your the first I've seen not able to figure out that stuff takes up space on a phone. Maybe you need to clear what you don't use and not need off your phone or maybe install an SD card to store music, photos, podcast, documents, and other downloads. That way your internal memory will stay clear unless you download a lot of apps. Next time if you want more storage you might want to shoot for a phone with greater internal memory. If you had a phone other than the Galaxy Note II you might be stuck if it doesn't have a micro sd card expansion slot.
    Thank you. You must be correct that I can't figure it out........
  4. #4
    Golfdriver97's Avatar
    Posts
    Global Posts
    32,738 Global Posts
    Carrier
    Pure Nexus/Franco Kernel
    Quote Originally Posted by Casey Cheung View Post
    You should be able to click on each category. That may bring up a list that details what each category consists of.
    Another thing to try is clearing cache in recovery.
    From a Sprint Moto X using AC Forums app
  5. #5
    NotJustAPhone's Avatar
    Posts
    Global Posts
    11,776 Global Posts
    Carrier
    GS3: CleanROM / N4: AOKP
    Please keep the discussion civil and on-topic. I suggest that those participating here acquaint themselves with the forum rules.
    Sent from my Galaxy Note II
  6. #6
    GeekCop's Avatar
    Posts
    Global Posts
    187 Global Posts
    Clear your cache, move whatever you can to your SD card, and look at your miscellaneous files (there's probably stuff in there you didn't know you had). If there's items you want to keep, and aren't necessary for the operation of your device, you may want to consider moving them to a Google Drive or Dropbox.
  7. #7
    Lightbulb Re: "Your device doesn't have enough storage space to synch." - Low memory error msg
    I am also seeing lack of space message from Android 4.4 KitKat Tablet. It's easy to say there's insufficient memory space "so remove some stuff."
    However, I have 16Gb of SD1 and 32Gb of SD2. I have moved several Apps "to SD card" with some success but....... I still get the message about being unable to synch.
    Now it looks to me as if just 1Gb is allocated for the OS and other Apps. Some of these cannot be moved "without rooting." Whatever does that mean? A funny expression isn't it? So how do I do that? One large App of mine won't work at all when it's "MOVEd TO SD CARD"
    This Android so full of promise but one needs a course to get into the right frame of mindful thinking. Anyone out there can point me to something understandable where the name of the game isn't just to show off how much gobbledygook can be uttered. Please....!
    BJ
  1. HTC One: How to install OTA Update? Rooted.
    By Master T in forum HTC One Rooting, ROMs & Hacks
    Last Post: 11-20-2015, 08:05 AM
  2. Replies: 2
    Last Post: 08-27-2014, 01:56 PM
  3. How to set up texting on Moto G without LTE
    By Awra in forum Moto G (2013)
    Last Post: 02-03-2014, 06:42 PM
  4. Phone Memory FULL SUDDENLY!!
    By Sudhanshu Jaiswal in forum HTC One S
    Last Post: 01-30-2014, 06:36 AM
  5. Foolishly.....I switched to the Samsung Note 8 :(
    By AldousSnow in forum Google Nexus 7 Tablet (2013)
    Last Post: 01-16-2014, 07:15 PM
