Results 1 to 12 of 12
    Exclamation Contact dup's for over 300 peeps help!
    I have a Note2. I want to merge all my contacts as I see more than 1 google contact then there are the FB, Twitter, LinkedIn and regular phone contacts, I see like 4 or even 6 of the same person. I know I can "join" them. I have done this for over a year. I have more than 300 contacts and because I have had to replace my phone several times this happens again and again.
    What can I do to have all my contacts merged into just one, have all that backed up onto Google so if I loose my phone or something it just restores to have 1 person instead of all these duplicates?
    Also, I want to do that for my calender too... Help???
  2. #2
    ramonm2's Avatar
    Posts
    Carrier
    Stock
    Default Re: Contact dup's for over 300 peeps help!
    go to your contacts. Click menu, click merge with google and a little g should pop up next to everyone's name. and make sure every time you add a contact add it as a google contact.
    Thank you but this is what I see when I click "menu"Click image for larger version.
ID:	101635 No "Merge" option...
  4. #4
    You have to choose a contact, then menu, and link.
    Personally I would start over.
    Install contact remover.
    I don't bother syncing my contacts, I export them to a file on my sdcard.
    If I have to factory reset or get a new phone I can easily import them.
    Yea, that would be great but... I just looked and I have 1948 contacts.. No joke. I own a company that is state wide and have been in business for over 11 years. So.... I have a big database of past clients and contacts.. Uggggggggggg
  6. #6
    Google has some de-duplication option if I recall in their contact managent page in gmail
  7. #7
    Just tried what firstov said and it worked. At least on the gmail contacts list. I haven't synced on my phone yet. It was really easy. click on the more button to the right of the groups button and click on merge duplicate contacts.
  8. #8
    Nibs's Avatar
    Posts
    Global Posts
    214 Global Posts
    My contact list is a mess also. I've tried managing them on google's end and the phone's end. I have hundreds of contacts now, there;s even people I don't know. Everytime I go through and fix the list up it just ends up going back to the way it was.
  9. #9
    rocco225's Avatar
    Posts
    Global Posts
    189 Global Posts
    I think this will work. I've had to do it myself over a year ago but the feature set still exists.
    I tried to paste my step by step in this forum but it keeps %^&-ing with my outline format. Go here for instructions and let me know how it works out:
    https://docs.google.com/document/d/1...it?usp=sharing
    Roc
  10. #10
    My problem with this is that I prefer my contacts to be Phone contacts, not Google contacts. Most of my Google contacts don't have phone numbers, so I don't need them to be in my Contacts. Most of my Phone contacts don't have email addresses associated with them, so they don't need to be in my Google contacts. The step-by-step method mentioned here excludes Phone contacts.
  11. #11
    rocco225's Avatar
    Posts
    Global Posts
    189 Global Posts
    I understand this preference although it does somewhat diminish the sync capabilities of your android phone. If you make a change to a phone contact it will not sync on the Google side. Keeping every contact as a "google contact" will allow you to group and manage contacts more quickly.
    Quote Originally Posted by Mustachio View Post
  12. #12
    I have 888 Google contacts. Of those, about 75 are relevant. The rest are relative strangers that I've emailed perhaps once since I got my Google account, back in the old days when Gmail was still in beta. About 99 percent of this distant group don't have phone numbers in their contacts. Not even a name for most either...just an email address. You can probably see now why I don't want all that crap in my phone. I'd rather not delete the contacts from my Google account for various reasons.
    What Google SHOULD do is add a Contact Group to their contacts that accepts Phone-Only contacts. That would let me sync up just fine.
  1. How can I make sure contacts are synced to my Google account?
    By House seller in forum AT&T Samsung Galaxy S4
    Last Post: 10-17-2014, 06:40 PM
  2. Tablet Bricked: Stuck at boot screen. HELP!!!!!!
    By PixelArt56 in forum General Help and How To
    Last Post: 03-24-2014, 03:40 AM
  3. Receive Alerts from Specific Contacts while on Silent?
    By anri69 in forum AT&T Samsung Galaxy Note 3
    Last Post: 01-22-2014, 11:32 AM
