Results 1 to 13 of 13
    FSchmitthammer's Avatar
    Posts
    Global Posts
    110 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Verizon Galaxy Note 2 Wifi Totally Unstable After Update
    My wifi has become unstable after the last update.
    I have tried clearing cache and other things I found on the Internet.
    Does anyone have a known solution?
    Sent from my SCH-I605 using AC Forums mobile app
  2. #2
    GeekCop's Avatar
    Posts
    Global Posts
    187 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Galaxy Note 2 Wifi Totally Unstable After Update
    Have you actually experienced instability or or you just getting a message that your connection is unstable?
    Posts
    Global Posts
    110 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Both
    Sent from my GT-N8013 using AC Forums mobile app
  4. #4
    jlost's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Verizon Galaxy Note 2 Wifi Totally Unstable After Update
    I had my phone on the 5ghz radio and would get a crappy connection unless I was right next to the ap. I switched it to the 2.4 GHz radio and all is good now. Fast and can go all around the outside of the house and not have a problem. Check to make sure your on the 2.4 GHz and if not change it to that and see if that works.
    Posts
    Global Posts
    110 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Is this controlled by the phone or the ap?
  6. #6
    jlost's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by FSchmitthammer View Post
    I don't understand what you are asking here.
  7. #7
    stephen Younger's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Actually I fixed a similar issue by going into my WiFi settings, long press on my home network then switch from dynamic to static under ip settings. Cheers.
  8. #8
    snowwy66's Avatar
    Posts
    Global Posts
    529 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    mine is working just fine.
    i have no idea how to change the things you guys are changing. or even where to look.
  9. #9
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by snowwy66 View Post
    What did was go into settings of my WiFi home network and changed from dynamic to static and then I stopped getting megs about my WiFi connection being unsecured. Hope this helps.
  10. #10
    snowwy66's Avatar
    Posts
    Global Posts
    529 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    oh. your talking about wifi. ROFL.
    i was thinking of hotspot. guess i'll have to test it IF and WHEN i get back home.
  11. Thread Author  Thread Author    #11
    Posts
    Global Posts
    110 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I reset the phone to factory. Still no joy.
    So from what I am reading here, it is working to not have DHCP for the IP address for the phone?
  12. #12
    opjones's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Pure Google/CM7
    Same issue here, so pissed. My phone has been great ever since i purchased it, then this ****ty samsung update, WTF!
  13. #13
    Craig Smith6's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I had the same trouble and found that since the update my phone had changed to the 4G network so I changed the setting in my phone: Settings\ More networks\Mobile Networks\Network Operators/search then change back to the listed 3G now it works fine.
  1. Replies: 12
    Last Post: 10-23-2014, 10:22 AM
  2. Samsung galaxy Note 3 issues after kitkat 4.4.2 update in India
    By Rakesh Singh4 in forum Android 4.4 KitKat
    Last Post: 09-15-2014, 07:53 PM
  3. Samsung Galaxy S5 Prime or Galaxy F Report.
    By Anon8154066 in forum Samsung Galaxy S5
    Last Post: 03-16-2014, 05:40 PM
  4. Samsung Galaxy S3 randomly turning on data
    By nalz in forum Samsung Galaxy S3
    Last Post: 03-15-2014, 10:18 PM
  5. Galaxy Tab 3: Nice Battery
    By Relgoshan in forum Samsung Galaxy Tab 3
    Last Post: 03-15-2014, 04:41 AM
