Results 1 to 8 of 8
    Default after Kit Kat update, wifi sometimes doesn't turn on after phone wakes up
    I'm wondering if anyone else has seen this problem.
    After the Kit Kat update, my Note 2 works just fine.
    However, wifi sometimes doesn't turn on after the phone wakes up. If I go into the wifi menu under settings, I can't change between on and off. The button is just greyed out. The only way around it is to turn airplane mode on and off and then go back into the wifi menu. At that point, wifi can be turned on again.
    I have already tried restoring the phone completely twice. The issue still persists.
    Any advice appreciated!
  2. #2
    Golfdriver97's Avatar
    Posts
    Global Posts
    21,647 Global Posts
    ROM
    Liquidsmooth ROM
    Default Re: after Kit Kat update, wifi sometimes doesn't turn on after phone wakes up
    Have you tried clearing the system cache in recovery?
    Phone Timeline
    'If we could change ourselves, the tendencies in the world would also change.' - Mahatma Gandhi
    Community Guidelines and also here
    Quote Originally Posted by Golfdriver97 View Post
    Yes.... when that didn't work, I did a factory reset.... then cleared system cache again.... followed by another factory reset.
    I have two Verizon Galaxy Note 2 phones and they're both having the exact same problem after Kit Kat.
    The problem does not appear if I allow the phone to keep wifi on during sleep.(by selecting "always")
  4. #4
    Quote Originally Posted by yourphonemyphone View Post
    I KNEW there was a reason I wanted to keep my unlimited data. Cost me a ton of money to buy two Note 2's though! (the wife gets pretty much everything I get, and sometimes more. )
    ie, I wouldn't know if my phone would do what yours has been doing as I never enable wifi except for Chromecasting, which is a pain. I hope we see CC work using mobile data sometime soon.
    Verizon Note 2 on 4.4.2 and Gear 2
  5. #5
    philmair's Avatar
    Posts
    Global Posts
    113 Global Posts
    I have exactly the same problem. WiFi greyed and cannot switch it on. Restarting the phone solves it ... for a few hours.
    It seems to happen each time I leave a WiFi location and it switches to network data .. it just "forgets" it's got a WiFi option.
    Quote Originally Posted by philmair View Post
    I also tried it on a CLNR Note 2 that Verizon sent me. I was able to replicate the exact same problem, so I returned it back to Verizon. The problem clearly was somewhere in the new Kit Kat OTA update.
  7. #7
    I have exactly the same condition. After last update wi-fi will not turn on unless you turn on airplane mode and then turn it back off.. Also I have found with location set to High Accuracy any app that uses GPS (google maps, map my walk) will not work unless you turn off location and then turn it right back on.. thinking maybe the S3 has problems with update 4.4.2. It is sure getting to a pain in the bottom...Hope someone comes up with a fix!!!!
  8. Thread Author  Thread Author    #8
    Quote Originally Posted by tnicodemus View Post
    Verizon will release an update to fix this problem. Hopefully it will be out by Groundhog Day.
  1. Every minute appears "no response" on homescreen
    By Diana Sim in forum Samsung Galaxy S4
    Last Post: 07-22-2014, 05:22 AM
  2. Has Anyone Seen this Pop-up?
    By awriternot in forum Samsung Galaxy S5
    Last Post: 07-19-2014, 02:57 PM
  3. Is it possible to downgrade the SM T210 from Samsung?
    Last Post: 07-18-2014, 11:31 AM
  4. S4 Active stuck, on power on att page
    Last Post: 07-17-2014, 10:32 AM
  5. Will Chromecast work with my phone?
    Last Post: 07-17-2014, 10:16 AM
