N NHBass39 Well-known member Sep 6, 2010 840 7 0 Visit site Feb 4, 2015 #1 I want to upgrade to kitkat, but after I unrooted I go to software updates and it hangs then goes back to the main screen. Any ideas. I did not format. Please help!
pool_shark Well-known member Aug 21, 2010 1,779 75 0 Visit site Feb 5, 2015 #3 You want to take the OTA update to 4.4? Are you aware that it limits apps writing to the sd card? You would be better off installing a 4.4 ROM if you unlocked your bootloader. Aside from that, if your device status says modified or the Knox counter was tripped that can cause the update to fail.
N NHBass39 Well-known member Sep 6, 2010 840 7 0 Visit site Feb 5, 2015 #4 I unrooted already is there any way you could help me get, 4.4 and provide a good rom?
pool_shark Well-known member Aug 21, 2010 1,779 75 0 Visit site Feb 5, 2015 #5 The 4.4 ROM I plan on installing this weekend is alliance. [Rom][4.4.2] AllianceRom_VZW Build 30 - 32 T… | Verizon Samsung Galaxy Note II | XDA Forums
N NHBass39 Well-known member Sep 6, 2010 840 7 0 Visit site Feb 5, 2015 #6 Can you walk me step by step. I am not familiar with installing a rom
pool_shark Well-known member Aug 21, 2010 1,779 75 0 Visit site Feb 5, 2015 #7 I don't know if your bootloader is unlocked or not. If it isn't and you're on 4.3, you can't unlock it without going thru quite a bit. Here is a link for all the info you need. Verizon Galaxy Note II Android Development - XDA Forums
