Hey all,
So I have had my Note 2 since a month before launch. I did get a refurbished one under warranty 6 months ago. Out of nowhere the phone would just freeze in the screen off position. I called support enough they sent me a replacement free of charge. So now that I essentially have a new phone (Runs great) I would like to get a battery to bring it back to the beginning days of 20+ hours of moderate use. I am currently down to 13 hours before needing the charger. I laugh because my Thunderbolt never saw 13 hours when new and on standby HAHAHA. So anyway, onto my question. I want to get a new battery for the phone. I want something that doesn't need a different cover. I don't want to spend a lot. And I would also like it to be from a Amazon Prime seller. I know I can get the OEM battery for around $9 up to $20. Are there other brands and bigger capacities that I should look at? Or just go for the original? I don't want to get extended if the back of the original case doesn't fit.
Thanks,
Brandon
Thanks,
Brandon
