02-12-2014 04:50 AM
60 123
tools
  1. xderiwx's Avatar
    Hi,
    First, thank you so much for your guide and taking the time to put it together. It really helps! I have a quick question:
    For IMEI backup, is the method outlined in the guide still the recommended way of doing it, with combining three backups, terminal emulator/adb + synergy rom zip + a qpst backup? I ask only because i have seen a few different ways while searching and since threads and development for these things can move so fast, i just wanted to make sure i do it right with the most up to date or recommended way.
    Thank you!
    01-31-2013 08:42 AM
  2. papa54's Avatar
    nope ..still zips.. or .rar same same
    - - - Updated - - -
    02-02-2013 07:14 PM
  3. benzman0210's Avatar
    I no wat ur problem is i had same thing before. That id ur stock rom i guess or something and u have to go and install whichever recovery program u want than reatart back into recovery mode that rom is missing the recovery program each time u exit out that screen it just looses it and each time u have to reinstall it b4 u go back into recovery mode
    03-09-2013 09:29 AM
  4. sansman8650's Avatar
    I want to use Darthstalker Rom on my gs3 verizon using pageplus. I was told to ask this question. Find out if there is a manual program method included in the rom so that a number can be manually programmed into the phone also if the SPC code is defaulted to Six zeros. Is a PRL able to be flashed to the phone VIA CDMA WORKSHOP. Can you disable 4g LTE completely and change to NV ONLY for 3G/ 1X speeds.
    03-09-2013 01:06 PM
  5. OneLostHero's Avatar
    The VZW-GS3-EZ-Unlock is no longer in the play store, what should we use to unlock now?
    06-26-2013 01:54 PM
  6. GSDer's Avatar
    https://play.google.com/store/apps/d...meff.ez.unlock
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk 4
    06-29-2013 11:52 AM
  7. Lee Sobczak's Avatar
    Do these instructions (sorry guys) guide me through step by step on how I can flash / unlock my Verizon GS3 (including modem)? I've read them, but wanted to make sure. I can read, but have no common sense. (Seriously) Thanks for your reply...
    07-13-2013 09:54 PM
  8. eoniverse's Avatar
    Thanks for the guide. I have a basic question that is driving me nuts. (Short drive) I have the US Cellular S3 version (R535). It came rooted and flashed to Page Plus Cellular (a Verizon reseller) when I got it. Would I use Verizon approved ROMs on this phone (since that's my network) or would I use US Cellular/ Universal ROMs (to match the hardware)?
    I feel like a doofus asking this but the last thing I want to do is put an incompatible ROM on this.
    I hope it's clear I am not asking about 'how to' flashing from one carrier to another. Just asking about ROM choice.
    11-04-2013 07:40 PM
  9. Jeffery Pratus's Avatar
    I made a HUGE mistake and accidentally installed a ROM for the International version of the phone and now it won't boot at all. Is there anyway at all to fix this?
    11-10-2013 11:45 AM
  10. Jasen Ulmer's Avatar
    I used CASUAL to root/unlock and flash TWRP. DOESN'T WORK ON Android 4.3 OTA updated phones!
    Here's the link below:
    http://forum.xda-developers.com/show....php?t=2332825
    "Libertatem Aut Mortem"
    -Samsung GSIII (CM10.2.1)
    -LG Lucid (CM10)
    -LG Revolution (BrokenOutRevo 2.0.1)
    -Samsung Fascinate (CM7)
    02-12-2014 04:50 AM
60 123
