Used Odin 3.07 for SG3...
I WAS using 3.01... and that didn't cut it. Make sure you include the 3.07 .ini file in with the exe.file (I used the youtube video here: How to Unroot / Unbrick the Samsung Galaxy S3 - Latest - YouTube
If you don't include the .ini file in the same directory, you'll just get a Korean warning notice of some sort.
AND DON'T FRICKING USE BEATS INSTALLER!
Brand new GS3 Just rooted using Debugfs Root, which worked very well. Added beats audio for root from google play.
It rebooted and got stuck at the 4g LTE part of the boot up.
I booted into recovery (volume up/power/home) deleted the cache... no difference.
I booted back up into recovery and did a factory reset. Again, no difference.
Tried to install factory image via Odin: no joy... says there is "no memory."
Can boot into recovery or Odin downloading. Can I put a rom on the chip and try and get something in that way?
I've GOT to have this thing working and fast. What else can I do?
