rooted verizon s3 help
angelisawesome
144
Is there anyway to make my verizon s3 run t-mobile 4g? I have it connected to t-mobile but it runs on edge. Its not that slow but it dosent let me watch netflix. So is there anyway to trick the phone into thinking that its on the 4g network or is there a carrier that i can use. Thanks
GSDer
8,471
15
Have you contacted T-Mobile to see if there are APN modifications that you need to make? I don't think it's a matter of just putting a T-Mobile SIM in the phone.
Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM 10.2 using Tapatalk 4
angelisawesome
144
Ive gotten my apns from the internet they work but only for 2g.
Is there another carrier that i can use that will run 3g or 4g?
nyry
343
The radios in VZWs GS3 only support mostly 2G GSM bands, some 3G GSM bands, and no 4G GSM bands
WillyC
