Results 1 to 12 of 12
    Greg Speare's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Help rooting android 4.3
    Hi i just bought my Samsung Galaxy S3 today and one of my friends keeps telling me to root my phone but i have never done anything like this before, and i have no idea what im doing. ive been trying to look for stuff online but it all seems a little confusing so i was just seeing if there is any one that could help me, also i keep hearing about a boot loader not sure how to unlock that because i dont want to brick my new phone.
  2. #2
    dadathepanda's Avatar
    Posts
    Global Posts
    1,165 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Help rooting android 4.3
    If you just got the s3, you may be on an older android version which means you can still root. But before doing anything go to Settings, about phone and check the Android version you have installed. If it says 4.3, then you can root but can't unlock bootloader. Anything below that version can be unlocked and different rom installed. Let us know!
  3. #3
    GSDer's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Saferoot http://forum.xda-developers.com/show....php?t=2565758
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk Pro
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I just looked and yep i have version 4.3
  5. #5
    Posts
    Global Posts
    1,165 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Then you're only going to be able to root. I believe the link posted earlier can help you with that. Good luck
  6. #6
    Casey Eberhard's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Can the phone still be unlocked if it is rooted? Even if I can't unlock the bootloader?
  7. #7
    GSDer's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Casey Eberhard View Post
    If you mean 'unlocked so that you can use it on a different carrier' the answer is yes, sort of - you don't need to unlock it to use it on another carrier: set it to GSM, shut it down, put your SIM card in, power it up and configure your APN settings.
  8. #8
    dpbklyn's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I am confused about the ability to install CM using SafeStrap on a Verizon S3 that took the OTA 4.3 update. Is it possible, or not?
  9. #9
    GSDer's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by dpbklyn View Post
    Welcome to the forums!
    Your best bet is to go to the source and pose your questions http://forum.xda-developers.com/show....php?t=2565758
  10. #10
    Posts
    Global Posts
    1,165 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Seems you can only install a few (two) roms once you have 4.3 and neither is CM. I had flashed a rom by old&slow? but it was very buggy and just quit.
  11. #11
    Sam Thompson1's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    i am new here and this was a while ago you posted this..but
    how do i root my Galaxy s3 SCH i535? its on jelly bean. 4.3
    I tried with saferoot..and it says your kernel is patched
    this device is not supported?
    im not sure what to do as im not the best with this stuff... but i cant seem to find anything
    i just want to root it to be able to use some apps that require root
  12. #12
    GSDer's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Sam Thompson1 View Post
    This device is supported. You made sure you're using the current release of Saferoot?
    Have you tried posting in their forum? http://forum.xda-developers.com/show....php?t=2565758
    Have you messed with your firmware in the past?
  1. Help with transfer from S4 to Note 3, what's the best method?
    By FutureKix in forum Samsung Galaxy Note 3
    Last Post: 02-28-2014, 04:00 PM
  2. Android browser problems
    By Crosswhite17 in forum Android 4.4 KitKat
    Last Post: 02-26-2014, 11:29 PM
  3. Future Android User
    By Dominick079 in forum Introductions
    Last Post: 02-25-2014, 09:22 PM
  4. SD card only usable by main user (Android 4.2)
    By r34d3r in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 02-25-2014, 05:30 PM
  5. Replies: 1
    Last Post: 02-25-2014, 02:53 PM
