Going to start that I take no responsibility for these modems or anything involved with them, posting them here so that others can benefit from them. Thanks to invisiblek over on XDA you can flash new modems to your phone to possibly improve your signal.
[WARN]These files are only ODIN flashable files. If you want Recovery flashable files, head over to Rootz for the original thread found here... http://rootzwiki.com/topic/34053-officialmodems-vrlhe-verizon-sgs3-sch-i535-odin-or-recovery-flashable/[/WARN]
I take no responsibility for what you do to your phone and you do flash these at your own risk.
Original post over on XDA:
Source: [OFFICIAL][MODEMS] Verizon SGS3 (SCH-I535) - xda-developers
All credit goes to invisiblek for his work.
[INFO]I have not tested the newest HD modem. I am currently running G7 modems from the latest OTA and have not had 1 issues with radios. Flashed with ODIN and worked perfectly fine.[/INFO]
FLASH IN THE PDA SECTION USING ODIN
Always flash EVERYTHING for this device in PDA unless otherwise noted.
I will not promise anything as far as faster speeds or better coverage.
IMPORTANT:
DO NOT FLASH ON ANY OTHER DEVICE THAN THE VERIZON GALAXY S3 (SCH-I535)
Do not unplug while this is happening, unless you are in dire need of a paperweight.
Odin tends to seem like it hangs for a short bit toward the end of the flash. Be patient, it will finish and automatically reboot.
Not flashing? Seems hung? See here: http://forum.xda-developers.com/show...5&postcount=13
Latest one is on top.
I535VRLHE - I535VRLHE on Goo.im
From newest Verizon OTA.
I535VRLHD - I535VRLHD on Goo.im
Leaked from an ICS Based ROM.
I535VRLG7 - I535VRLG7 on Goo.im
This is from the first official OTA
I535VRLG1 - I535VRLG1 on Goo.im
This is from the unreleased original OTA
I535VRLF2 - I535VRLF2 on Goo.im
This is the original shipped modem
I535VRLEC - I535VRLEC on Goo.im
This is from a leaked pre-release version of our phone
FAQ:
Q: Should I flash this in clockworkmod?
A: No, read this entire post before trying anything.
Q: Should I flash this in the Phone section in Odin?
A: No, see previous answer.
Q: Can I flash this if I am running an AOSP rom? (CM9,CM10, AOKP, etc)
A: Yes, this is not dependent on what your phone is running.
Q: Do I need to be rooted to install this?
A: No
Q: Will this wipe my data?
A: No, it will ONLY update your baseband, nothing else. Everything in your ROM should act just as it has.
Q: How can I check that it's been updated?
A: Go to Settings > About Device > Baseband version
