04-30-2016 10:18 PM
32 12
tools
  1. MjDroidx's Avatar
    I have the same problem. My bootloader isn't unlocked yet either. The way around this I found was to put it downloading mode, then click cancel and then reboot.
    01-03-2014 07:29 AM
  2. GSDer's Avatar
    Are you asking for help, or just making a comment about how you deal with the problem?
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk
    01-03-2014 05:00 PM
  3. fancreator's Avatar
    Hello from cuba.
    i have a sch-i535 de verizon. trying to install a new recovery in order to flash a custom room. My phone have a problem somewhere in the motherboard and IS NOT recognized for the computer so i CAN´T use odin. I download 2 apps rash and twrp manage to installa a custom recovery, i download the files for my phone sch-i535 d2vzw the most advanced version and flash it. whe reboot i got this message "system software not authorized by verizon wireless has been found on your phone. prease turn off your phone and go to the nearest verizon wireless store for help."
    I survive entering in download mode (power+home+ volume -) and when ask me to continue y set restart phone and the problem was solve. i was able to enter in my phone but never again in my recovery mode....
    so i open rash app and try to restore a backup i did before all this shost in case and when reboot pass the samsung logo and get a green android with a red triangle and message NO COMMAND. them appear
    android system recovery <3e>
    KOT49H.I535VRUDNE1
    Volume up/down to move highlight;
    power button to select.
    reboot system now
    apply update from ADB
    apply update from external storage
    wipe data/factory reset
    wipe cache partition
    apply update from cache
    (bad android logo)
    #manual mode#
    -- Appling Multi-CSC...
    applied the CSC-code : VZW
    Successfully applied multi-CSC.
    look like my old recovery but nothing function
    i press reboot and say error and reboot the same screen
    the same with hard reset say error and reenter
    now i don't know what to do... remember i CAN'T use a pc
    WHAT CAN I DO??????? Help please!!
    02-29-2016 11:06 AM
  4. Rom-er's Avatar
    Hello from cuba.
    KOT49H.I535VRUDNE1
    reboot system now
    (bad android logo)
    #manual mode#
    The firmware you have(NE1) has a locked bootloader, you will never be able to use CWM/TWRP or custom/AOSP ROMs.
    Your device has to use Safestrap Recovery and modified stock TouchWiz ROMs.
    Do search for:
    "Safestrap Recovery for Verizon S3"
    03-06-2016 01:54 AM
  5. fancreator's Avatar
    I unbrick my phone. result that the pc did recognize it using odin. so i download the official stock firmware and flash it and is alive... wow great....
    So I still want to upgrade to llolipop.... there is no way to unlock my NE1 bootloader??????
    Thanks!!!
    03-15-2016 02:05 PM
  6. Rom-er's Avatar
    Thanks!!!
    No, Safestrap with modified Stock ROMs is your best option.
    You will not be able to flash anything truly custom at all, no custom recovery(TWRP/CWM) or custom ROMs (CM/AOSP), period.
    Only stock based ROMs.
    03-27-2016 05:39 PM
  7. Timothy Leyva's Avatar
    I locked myself out of my phone by trying to root it with a kingroot app on my Samsung galaxy note 4 and now i can't get anything but the orange triangle say unauthorized software or i can put it in download mode, is there anyway I can recover w/o resetting to stock and still keep it rooted. I don't want to erase every thing to stock BC I have pictures of my first born son as a baby and I don't have anything backed up at aall.Thank you
    04-30-2016 10:18 PM
32 12
