Results 1 to 6 of 6
    eyar's Avatar
    Posts
    Default Not able to unlock the Verizon galaxy S3 using ezunlock 1.4 after rooting the phone successfully
    I have Verizon samsung galaxy s3 (sch-I535) which i am looking to unlock it. I was able to root the phone successfully and after that when i am using the vzunlock 1.4 utility to unlock the phone its saying unlocked and device status is unknown, i have tried googling on it and found version 1.2 works fine as 1.4 has issues. but i am not able to find or download that version can some one please lemme know where i can download the older version or if they can attach it here it would be gr8.
    Also will i be able to use the phone outside US on local carriers without actually having the phone unlocked.
  2. #2
    Default Re: Not able to unlock the Verizon galaxy S3 using ezunlock 1.4 after rooting the phone successfully
    Quote Originally Posted by eyar View Post
    Global Phone?
    Global Phone?
    http://forums.androidcentral.com/sho... Global Phone?
    Sent from my SCH-I535 using Android Central Forums
  3. #3
    Version 1.4 works fine just shows "unknown". This has already been discussed several times. If you want an older version, here you go.
    Steve
  4. #4
    Just so we're clear, this "unlock" tool is for unlocking the bootloader, it doesn't unlock the phone's carrier status (or whatever that's called) to allow you to use it on other networks.
    I have no idea how that all works, and perhaps the info linked to in the post quoted below can help answer those questions, but just know that the unlock tool you refer to is only referring to unlocking the bootloader for loading custom software.
    Quote Originally Posted by flatblader View Post
    Global Phone?
    Global Phone?
  5. #5
    Hello,
    I tried the ez unlock and it said I have to be rooted first. Any easy roots for JB verizon gs3? Or does the purchasing unlock code method work? Thanks for the help
  6. #6
    This will give you root, custom recovery and unlock your bootloader.
  1. [Guide] Root/Unroot/Recovery/Unlock Bootloader for the Verizon Galaxy S3 (SCH-i535)
    By Cyber Warrior in forum Verizon Galaxy S3 Rooting, ROMs, and Hacks
    Last Post: 05-19-2013, 04:39 PM
  2. Replies: 6
    Last Post: 10-04-2012, 04:13 PM
  3. for those still not able to get the update....
    By 0pusX in forum Verizon HTC Thunderbolt
    Last Post: 07-09-2011, 04:49 PM
  4. Replies: 7
    Last Post: 09-03-2010, 02:21 AM
