Running AOKP Milestone 1 and have bluetooth issues, anyone else?
My bluetooth works in my car but every once in a while it wont sync unless I shut the bluetooth off and then on again. It is a little thing but it is the only thing that is not 100% stable for me.
Is anyone else having bluetooth issues? Is there an easy fix for this?
If everyone else's is fine I might just re-flash everything, thanks in advance.
Re: Running AOKP Milestone 1 and have bluetooth issues, anyone else?
My BT sounds like crap, clips every 2seconds, starts going faster than normal whenI play songs. I might switch back
If I'm not mistaken, bluetooth has been an issue on AOKP. Ask @protekk on twitter. name is jacob, he's a founding dev on the project.
