Results 1 to 14 of 14
    Harreh's Avatar
    Posts
    Global Posts
    124 Global Posts
    ROM
    Abeast v4
    Default Root problem. Please help
    So, I rooted my phone using RootDebugFS. The root went fine, SU was installed. Next I installed EZ Unlock and unlocked my bootloader. I then installed CWM and updated to the current (non touch) version. When all of that was done I booted into CWM to make sure I had root, and booted into CWM. I rebooted and downloaded Cyanogen Mod 10 from CWM. When the download was complete I let CWM begin the install.
    I went to take a shower while it was installing and when i got back i had this message "Sytem software not authorized by Verizon Wireless has been found onyour phone. Please turn off your phone and go to the nearest Verizon Wireless store for help."
    Is there anything i can do besides go to verizon at this point?
    Thanks,
    Harreh
  2. #2
    jlibis's Avatar
    Posts
    ROM
    CM10 M1
    Default Re: Root problem. Please help
    Quote Originally Posted by Harreh View Post
    Thanks,
    Harreh
    My guess is your phone didn't actually unlock.....ez unlock has had some issues lately. It has happened to many people, you are fine I'm pretty sure but I'm not exactly sure what you need to do.
  3. #3
    You have to Odin your device, here's the stock rooted ICS build/instructions -
    What do you mean you downloaded it through CWM? You should have grabbed the ROM from the official source, backed up your device, and wiped your data/cache/dalvik cache beforehand. Also the reason you got this issue is because you didn't properly unlock your bootloader. If EZ-Unlock says 'unknown' than go through the process at least 3 times before flashing anything.
    Galaxy S3 - Thanks Appreciated!
    My Podcast-
    My Blog-
    Thanked by:
    jpent
    Harreh's Avatar
    Posts
    Global Posts
    124 Global Posts
    ROM
    Abeast v4
    Thanks for the link. But I can't get into odin mode because it boots right to that verizon message.
    What I need to know is if there is any way to get around that verizon message so i can get to odin mode to flash my phone so i don't have to take the phone to verizon?
  5. #5
    Power off the device (Hold power button down until it restarts, or remove battery), as the device boots back up hold "Vol down" + "Home" + "Power" until you get the warning message, then press Vol+
    Harreh's Avatar
    Posts
    Global Posts
    124 Global Posts
    ROM
    Abeast v4
    I will give that a try when I get home tonight. I think I took the battery out and did that last night and it still booted to the verizon message, but I will try again before I take it to verizon. I have no clue what verizon will do, maybe flash it back to stock? Has anyone had to take a phone back when they have had the verizon message on it?
  7. #7
    I wouldn't take it to Verizon -- if you're getting that message, they'll know you attempted to install non-standard software, and thus your warranty voided.
    You should be able to get to download mode to flash a stock image with ODIN...this isn't as uncommon an occurrence you may think.
  8. #8
    Also did you use that root method with jelly bean?
    Sent from my SCH-I535 using Android Central Forums
    Harreh's Avatar
    Posts
    Global Posts
    124 Global Posts
    ROM
    Abeast v4
    Quote Originally Posted by blade22222 View Post
    No. 4.0.4
  10. Thread Author  Thread Author    #10
    Harreh's Avatar
    Posts
    Global Posts
    124 Global Posts
    ROM
    Abeast v4
    Ok. I found this over at xda. Im going to try this when I get home.
    forum.xda-developers.com/showthread.php?t=1762709
    Section 5.
  11. #11
    Section 5.
    I was also going to suggest completing step 1 of this guide...but it appears to be the same thing...
    Either way should get you up and running again.
    Thanked by:
    Harreh
  12. Thread Author  Thread Author    #12
    Harreh's Avatar
    Posts
    Global Posts
    124 Global Posts
    ROM
    Abeast v4
    Thanks for taking your time to help. Needless to say my stress level has dropped dramatically.
  13. Thread Author  Thread Author    #13
    Harreh's Avatar
    Posts
    Global Posts
    124 Global Posts
    ROM
    Abeast v4
    AAAAAAAAAAAAAAAARRRRRRRRRRRRRRRRRGGGGGGGGGHHHHHHHHH.....xda forum is down!!
  14. #14
    Although I do not have the Verizon message I am getting "unknown" when I check the status. Am I likely okay and should not worry about it.... or should I jump on this and redo this til I get it to no longer say unknown?
    Thanks!
  1. 1.5 root problem please help
    By excessive81 in forum HTC EVO 3D Rooting, ROMs, and Hacks
    Last Post: 01-05-2012, 09:14 AM
  2. Xoom Root problem Please help
    By billymaloney3 in forum Motorola Xoom
    Last Post: 11-21-2011, 08:43 AM
  3. Why the hell did i root my phone????? Problems, Problems, please Help.
    By careybrad in forum Thunderbolt Rooting, ROMs, and Hacks
    Last Post: 04-25-2011, 08:01 AM
  4. rooting problem...please help!!
    By lions80 in forum Motorola X Rooting, ROMs, and Hacks
    Last Post: 03-30-2011, 11:19 PM
  5. Rooting Problem, Please help
    By nate3382 in forum Incredible Rooting, ROMs, and Hacks
    Last Post: 08-27-2010, 10:43 PM
