Results 1 to 7 of 7
- 01-18-2013, 09:07 PM
Thread Author #1
- 01-19-2013, 09:51 AM #2
- 01-19-2013, 04:59 PM
Thread Author #3
Re: AC!D Audio Engine 5.0
I spent some more time with it today. Unfortunately the best bet for some kind of improvement is with the player it flashes, which is Walkman or Noozy. It doesn't play well with PowerAmp. I got more skipping on bluetooth using it too. I flashed my backup and took it off. Maybe someone else will have better luck with it.
- 01-21-2013, 01:39 PM #4
I flashed it Friday via the Aroma installer and Noozy player with Noozoide or whatever. Turns the stock earbud headset into something pretty amazing once you get it tweaked right. Fantastic bass response and clarity, especially on tracks with a decent quality sample rate (I'm using 224kb/s ogg). Noozy is a pretty neat player for JB too.
If you are inclined to spend a lot of money and want a pretty trophy with which to pass the next few years of your life that talks to you in a condescending voice, can't navigate to save its life, expects full control over all you do, demands $13 for a $3 purchase, allegedly has a single recessed button, needs an expensive computer and a credit card to do anything, hates your music and has purses designed just for it...New to LG's premium Android phone? Check out the Optimus S Welcome Guide.
Get married to someone you hate... or get an iPhone.
Used ROM Mangler on your Optimus S and having problems? Try this. - 01-24-2013, 07:39 AM #5
When you flash this or any other sound mod you have to go into settings sound music effects and change your DSP to Amazing Beats or Nooz...I do not suggest the walkman player unless you have all your music locally and it will not effect Pandora etc. Once you have chosen your DSP you need to open it up from your APP menu and start turning things on...Forums like this tend to bring in Noobs...If this one doesnt work please check out beats+xlouder mod for Gnex or Nex 7... odds are if this isnt working you have some rom that isnt AOSP based. I am using a GNEX with AOKP MR1 Build 2 which is 4.2.1 and it is amazing.
- 01-24-2013, 07:59 AM #6
- 01-24-2013, 03:40 PM #7
I flashed Acid on my phone and it sounds great. Just a few questions. When I plug my headphones in it pops up saying it's active, but with my bluetooth headphones and my car bluetooth is does not pop up in the status bar. Is it still working with those? Also I listen to all my music from Google Music are there any other add ons you guys would recommend? Thanks.
Sent from my Galaxy S3 running CleanRom 5.5.1Sent from my Galaxy S3 Running CleanROM 5.5.1
Send Audio MMS
By jhass#ac in forum Motorola DroidReplies: 5Last Post: 12-03-2009, 06:34 PM -
Is anyone listening to Audio books on the hero?
By mabmarc#ac in forum HTC HeroReplies: 2Last Post: 11-08-2009, 07:24 AM -
Stream Audible audio books from your PC
By mabmarc#ac in forum HTC HeroReplies: 0Last Post: 11-07-2009, 07:29 PM -
Bluetooth Audio Doesnt work on Hero
By cpwinters in forum HTC HeroReplies: 1Last Post: 11-03-2009, 09:49 PM -
HTC Audio Adapter no audio output after updated to Androd 1.5..
By aki in forum T-Mobile G1Replies: 1Last Post: 06-09-2009, 05:26 PM
Reply
