I've downloaded the mod in xda for 4.2.2 messaging, but I get a failed install. I'm thinking it's not for 4.2.2 ROMs but to get that feel in another rom. Anyone know how and where to get an inverted mms 4.2.2 mod?
Like so much fonzy.
Printable View
Like so much fonzy.
A lot of SMS and MMS app replacements on the Play Store have dark themes. The one I use [Only registered and activated users can see links. Click Here To Register...]has this.
The problem is that Carbon is not deodexed. Use root explorer, (or something similar), to delete the odex file associated with the mms apk. Should work fine after that.
In order to use anything that's been themed you have to be on a deodexed ROM or delete the odex file of the themed app you're installing.
Sent from my Liquid GS3.
Also, how are you installing?
Do you have the link to the mms apk?
