1. judgenot's Avatar
    Hello,
    I have a Samsung Galaxy S3(SCH-I535) and I'm running Slim Bean's 4.2.2 Rom build 8. I never really noticed this before because I haven't used a bluetooth headset that often. Now I use it a lot and I notice that even though in settings I have "media audio" unchecked for the Platronics Voyager Legend(bluetooth headset), it will start playing media through the headset randomly. For example, yesterday I was texting and suddenly the sound that is supposed to be played through the phone speaker for an incoming text started playing through the headset. Is there anyway to fix this issue? This also happens when streaming music using pandora as well at times, and once it has changed to playing through the headset, I have to turn the headset off and back on or it will continue to do so. Any help is much appreciated.
    Thanks
    09-04-2013 09:04 AM
  2. Golfdriver97's Avatar
    Hello,
    Thanks
    Welcome to the forums!
    Is build 8 the first ROM you flashed to?
    09-04-2013 09:19 AM
  3. judgenot's Avatar
    No. The first ROM I flashed was build 6, then 7, then 8. I did a wipe cache and dalvik wipe before each upgrade; however, I never did a factory reset as it didn't seem necessary.
    09-04-2013 02:06 PM
  4. Golfdriver97's Avatar
    Rule of thumb for flashing any ROM is doing all three. Slim even suggests to wipe /system for flashing.
    Sent from a SlimROM S3.
    judgenot likes this.
    09-04-2013 03:52 PM
  5. judgenot's Avatar
    Ok. I am going to do a FULL wipe including format/system. I will post the results after it is complete. Thanks for responding.
    09-05-2013 08:34 AM
  6. Golfdriver97's Avatar
    Just make sure you reflash the OS again.
    09-05-2013 08:50 AM
  7. judgenot's Avatar
    Ok, so I did a full wipe including format/system then reinstalled slim bean's build 8 for verizon S3(d2vzw) and also reinstalled slim gapps 4.2.2. As of now the bluetooth issue seems to be resolved and I find it even connects quicker. I appreciate the advice and will update if any issue arises.
    Golfdriver97 likes this.
    09-06-2013 10:14 AM
  8. Golfdriver97's Avatar
    Glad it worked. Thanks for posting the result.
    09-06-2013 04:22 PM
  1. Replies: 2
    Last Post: 01-16-2016, 12:54 PM
  2. No sound when playing back uploaded recorded videos
    By Hugh_Jass in forum AT&T ATRIX HD
    Last Post: 01-29-2015, 04:59 PM
  3. video play, network problem...
    By txzar in forum Google Nexus 7 Tablet (2013)
    Last Post: 09-05-2013, 05:20 AM
  4. I need help my play store has stopped working
    By Ralf Tabo in forum General News & Discussion
    Last Post: 09-04-2013, 11:08 PM
  5. Problem solved with audio jack in car.
    By Captainbob767 in forum Google Nexus 4
    Last Post: 09-04-2013, 07:59 AM
