Page 1 of 2 12 LastLast
Results 1 to 25 of 31
Like Tree2Likes
    Default When my phone turns on it states "System software not authorized by Verizon Wireless has been found
    I had update so to jellybean 4.3 and rooted my phone. I restarted and noticed a unlocked padlock on samsung start up screen. Once all booted up my wifi was not letting me enable it. I then used Odin to try to recover stock image and when the phone rebooted it states "System software not authorized by Verizon Wireless has been found on your phone. Please turn off your phone and go to the nearest Verizon Wireless store for help. " I took to geek squad who stated they could not help and verizon said they could not help either. Please walk me through fixing step by step and provide me with links as to what all I need. I tried Odin and it runs through loading a stock image but reboots to same message. I just want to restore to factory setting. Please someone help!
  2. #2
    Default Re: When my phone turns on it states "System software not authorized by Verizon Wireless has been fo
    Follow the link in this post http://forums.androidcentral.com/sho....php?p=3357249
    (4.3 update link) and you'll be able to use Odin to get back to stock 4.3 (un-rooted).
    You should be able to use Saferoot (follow the link in this post http://forums.androidcentral.com/sho....php?p=3348611
    [Rooting and 4.3]) without any issues.
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk
    Thanked by:
    Thanks I'm going to try it now.
    I am to the step of being in Oddin and checking off PDA box. When I search for the file "ALL_I535VRUCML1_I535VZWCML1_2198062_REV09_user_low_ship.tar.md5.7z" it does not appear. Is it because of the file extension being md5.7z? Should I rename it as md5 and remove the .7z?
    I unzipped file with pea zip and the rest worked great. Phone up and running again! Thanks!
    Deanig_12 likes this.
  6. #6
    There is an alternative and quick solution if you ever run into this issue ever again and it is tapping the volume and the power button a few times in a row while it is booting up in the unlocked screen code. It bypasses the Verizon error and allows you to boot up into the OS again. Just for your information. Take care.
    Thanked by 2:
  7. #7
    i have the same issue!!!!!
    how did you solve it?
  8. #8
    Quote Originally Posted by geNIUX50 View Post
    Which 'same' issue, and what have you already tried?
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk Pro
  9. #9
    what is the "unlocked screen code"?
  10. #10
    Quote Originally Posted by jwood7707 View Post
    Judging by the sparse information provided in the post that you quoted, I believe that the reference was to booting into Download mode, but instead of pressing Volume Up to actually enter Download mode you instead choose to cancel out of that process and the phone then boots normally.
    Thanked by:
    nolittdroid likes this.
  11. #11
    You get that locked screen telling you to go to Verizon store because your bootloader is locked. From what I understand 4.3 is still locked so no custom roms or zips can be flashed. You will need to use the stock unrooted 4.3 tar file in of in to get you back.
    Sent from my Wicked GS3
  12. #12
    Dude I have to thank you knowing nothing about phones I thought I was screwed. and its still rooted! wow thanks man!
  13. #13
    So I had the same issue and tried to tap buttons a couple time like someone above suggest but that did nothing. I simply pushed volume down, home and power at the same time. Then it asked a question and I chose to cancel, then it restarted and I hit volume down 2 times at the unlocked screen. I don't think the last step is necessary.....but thats what I did.
  14. #14
    How difficult is this process? I had a friend route my phone. Now I am getting the "system software not authorized". I have never preformed a process like this. I don't want to ruin my phone. Please help.
  15. #15
    Welcome to the forums!
    Quote Originally Posted by Katvail View Post
    How difficult is what process? There's several different solutions described; some provide a temporary workaround and some a permanent fix.
    Why don't you get the friend that rooted the device to solve the problem, since it sounds like it was a result of the rooting that you're getting this error?
  16. #16
    Quote Originally Posted by philrewa View Post
    Can I ask for details on your "last step?" I'm able to get to the question (prompt) with "Continue" or "Cancel". However selecting either of those options and pressing various buttons afterwards, does NOT seem to work.
    Also what are the consequences to taking it to the Verizon Store? Is it a slap on the wrist? Do they red flag your account?
  17. #17
    Thanks, I had the same prob, the info you posted work! Have not rooted it yet but my phone boots now.
  18. #18
    Hey Guys,
    I'm having the same problem with the error message "System software not authorized by Verizon..."
    On 4.3 rooted, bootloader still locked.
    Was being prompted to update software and once it rebooted I got the screen.
    Thanks for the help.
  19. #19
    Quote Originally Posted by drewc00 View Post
    Generally speaking, once your phone is rooted you can no longer accept OTAs. You'll need to use the Kies software or Odin to reload the stock firmware and then reroot.
    Sometimes you can boot into Download mode but cancel out at the first screen and the phone will boot normally, but you'll just have the same problem whenever you reboot.
    If you decide to use Odin you can find the latest stock firmware http://samsung-updates.com/details/2...35VRUCNC1.html
  20. #20
    Thanks!
    Are you able to give me instructions or link on how to apply stock firmware using ODIN? Don't want to screw anything up.
    Quote Originally Posted by GSDer View Post
    Welcome to the forums!Generally speaking, once your phone is rooted you can no longer accept OTAs. You'll need to use the Kies software or Odin to reload the stock firmware and then reroot.
    If you decide to use Odin you can find the latest stock firmware Samsung Updates - Firmware Download Page
  21. #21
    A Google search will turn up much better instructions than I can provide, including screenshots, etc. You can even find steps in most of the rooting sub-forums.
    Edit: http://forums.androidcentral.com/sho....php?p=2955016
  22. #22
    protenn69's Avatar
    Posts
    Global Posts
    2 Global Posts
    Thank you, this worked for me.
  23. #23
    eibbed0001's Avatar
    Posts
    ROM
    Stock rooted
    Default
    Just to confirm while I'm waiting on my download...
    I get the "System software not authorized by Verizon..." message and currently get around it by either not shutting down my phone or by shutting down, rebooting into Download Mode and cancelling out of the Download Mode option. I'd like to clean it up and start fresh so that I don't get that message anymore. I'm prepared to do the following because I think it will solve that issue but I figured I'd check here first to be sure. I plan to:
    1. Unzip and use Odin to run ALL_I535VRUCML1_I535VZWCML1_2198062_REV09_user_low_ship.tar.md5.7z
    2. Reboot the phone and make sure all is well.
    3. Run the Saferoot software to re-root the phone
    Can I still unlock the bootloader with EZ-Unlock? The link for Saferoot says no but I thought I'd read otherwise since my bootloader is currently unlocked.
    I believe what I cannot do is use EZ-Recovery to install a custom recovery, is that correct?
    Thanks for clarification.
    P.S. I already have a verfied Titanium backup and will restore (apps only, not data except for select apps) afterward.
    You know, I've never met anyone like you before. Usually when I meet someone new I feel awkward and shy. But with you it's different.
  24. #24
    Quote Originally Posted by eibbed0001 View Post
    No. I don't know why you think the bootloader is unlocked, but if you loaded the full blown 4.3 at some point then you're stuck with the Knox bootloader limitations.
    You cannot. But you can use Safestrap http://forum.xda-developers.com/show....php?t=2605648 to load some kind of modified Recovery that allows you to load alternate ROMs of some sort (very limited from what I remember reading).
  25. #25
    eibbed0001's Avatar
    Posts
    ROM
    Stock rooted
    Thanks, it all worked as stated. As far as I can tell my bootloader is unlocked - I get an unlocked image when the phone boots up and the EZ-Unlock app states that it's unlocked.
  1. LG G2 (Au) not compatible with Netflix
    By smiffy121 in forum LG G2
    Last Post: 03-29-2014, 08:19 PM
  2. Nexus 4: Anyone Else Getting Better Battery Life on LTE?
    By PhoenixMike in forum Nexus 4 Rooting, ROMs, & Hacks
    Last Post: 01-26-2014, 07:35 PM
  3. Replies: 5
    Last Post: 01-05-2014, 09:48 PM
  4. "Internet" Icon. What browser is it?
    By monicakm in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 01-05-2014, 01:02 PM
  5. question about samsung wireless charging cover
    By trdsol23 in forum Samsung Galaxy Note 3
    Last Post: 01-05-2014, 12:48 PM
