Results 1 to 11 of 11
    neil154's Avatar
    Posts
    Global Posts
    440 Global Posts
    Default Rooting my Verizon S3 running 4.4.2
    I would like to root my Verizon S3 running 4.4.2 but the rooting instructions I have found either do not apply to my OS or the directions have broken links.
    So I would appreciate it if you could provide me a link or directions to root my phone.
    PS: What is also the advantage to unlocking the Bootloader?
    Galaxy S5 16GB Not Rooted
    Verizon,USA
    Android V4.4.4
  2. #2
    Default Re: Rooting my Verizon S3 running 4.4.2
    Quote Originally Posted by neil154 View Post
    If you're running stock firmware you can't unlock the bootloader me... But if you look up towelroot you can root
    Sent from my SCH-I535 using Tapatalk
    neil154's Avatar
    Posts
    Global Posts
    440 Global Posts
    Thanks, I searched for "towelroot" on this forum and it seems to get good results but I don't see any links on getting or instructions I would appreciate a link if you have one
    Verizon,USA
    Android V4.4.4
  4. #4
    https://towelroot.com/ (run this from your phone)
    - click the lambda symbol- download the apk
    - install the apk- follow the instructions(Note that if you've installed the latest OTA from Verizon and your kernel is dated after June 3rd, this won't work.)
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk
    neil154's Avatar
    Posts
    Global Posts
    440 Global Posts
    Thanks for the link but my OTA is dated after 6/3/14 so it will not work for me.
    Does anyone have other suggestions on links for rooting
    Verizon,USA
    Android V4.4.4
    neil154's Avatar
    Posts
    Global Posts
    440 Global Posts
    Thanks for everyone's help, I have now successfully rooted my S3
    Verizon,USA
    Android V4.4.4
  7. #7
    Great! What method did you follow?
    And what firmware build are you currently on?
  8. Thread Author  Thread Author    #8
    neil154's Avatar
    Posts
    Global Posts
    440 Global Posts
    I am using ver 4.4.2 and I used https://www.towelroot.com/ and followed instruction from Easy one click: Verizon Galaxy S3 KitKat root - NE1 update | AndroMods
    Verizon,USA
    Android V4.4.4
  9. #9
    I tried opening towelroot on my phone with Chrome, and it just opened infinite new windows. Regular browser starts to open and then stops. What gives?
  10. Thread Author  Thread Author    #10
    neil154's Avatar
    Posts
    Global Posts
    440 Global Posts
    I don't know exactly what you are doing but I was able to get Towelroot to open fine, are you clicking on the red upside down "Y"?
    Verizon,USA
    Android V4.4.4
  11. #11
    I couldn't get it to download in Chrome but the Samsung browser worked fine.
  1. Stock or different launcher, root or not
    By chrisoldroyd in forum LG G3
    Last Post: 08-05-2014, 06:19 PM
  2. Samsung S3 GT-I9300 Suddenly Died
    By Lohd Waca in forum Samsung Galaxy S3
    Last Post: 08-01-2014, 08:43 PM
  3. Emojis turn to MMS on Galaxy S3
    Last Post: 08-01-2014, 02:19 PM
  4. Replies: 4
    Last Post: 08-01-2014, 02:03 PM
  5. What are you replacing your GNex with on Verizon?
    By Gratificulous in forum Google / Samsung Galaxy Nexus
    Last Post: 08-01-2014, 11:56 AM
