Results 1 to 4 of 4
    nedqadams's Avatar
    Posts
    Global Posts
    420 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Little Problems
    After playing with the phone the last two days I've noticed that the haptic feedback for the soft keys keeps turning off - 3 times so far. Not a deal breaker but a little annoying.
    Also, my data sync turned off at some point last night on it's own.
    Anyone seeing little hiccups like that?
  2. #2
    quake101's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Do you have the power saving settings enabled? If so, it can disable the haptic feedback.
    Sent from my SCH-I535 using Tapatalk 2
    nedqadams's Avatar
    Posts
    Global Posts
    420 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Little Problems
    I don't.
    Not entirely sure what it does so haven't selected it.
  4. #4
    sortiz_88's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks for the suggestion, it worked perfectly.
    Quote Originally Posted by quake101 View Post
