Results 1 to 25 of 34
- 07-09-2012, 10:34 AM
Thread Author #1
LED Notification Not Blinking
Before I send my phone back to get replace, my LED does not flash when I received a notification. It stays solid I try looking for a setting that may cause this problem, nothing. Lite flow does not work with the s3 is there anyone else having this same problem or know a fix for this.
Sent from my SCH-I535 using Android Central Forums - 07-09-2012, 10:42 AM #2
Re: LED Notification Not Blinking
lite flow doesn't work? Bummer
- 07-09-2012, 11:28 AM #3
LED blinks for me on some notifications, but not others. Gmail - no blink. Touchdown - blink. Will monitor others.
Dumb phone -> BB8830WE -> BB Curve 8330 -> Incredible -> DROID X ----->Galaxy S3 - 07-09-2012, 11:37 AM
Thread Author #4
- 07-09-2012, 11:50 AM
Thread Author #5
I was using handcent but since I uninstall handcent, when I get a text now it blinks.
Sent from my SCH-I535 using Android Central Forums - 07-09-2012, 01:49 PM #6
- 07-09-2012, 02:08 PM #7
Gmail, text, and missed phone call all blinks with blue led. This is with charger unplugged.
When plugged in to charger, the led stays solid red. Haven't tried with charger plugged in but I believe it turns solid blue if I receive a notification while charging. - 07-09-2012, 02:15 PM #8
- 07-09-2012, 02:21 PM #9
OP, when you installed Hndcent, maybe it dorked up your settings? Other have blinking blue (gmail above blinks blue).
- 07-09-2012, 02:26 PM #10
- 07-09-2012, 03:02 PM #11
- 07-09-2012, 09:32 PM #12
For me Gmail, Hotmail and missed call blink. Whatsapp and Go SMS don't blink.
- 07-09-2012, 09:45 PM #13
- 07-10-2012, 08:24 PM #14
I dont have LightFlow on my phone (never had) and noticed that it doesnt blink for some and instead chooses a solid-always on notification. This has to be a battery drain. Anyone out there try LightFlow to see if they could configure the LED to work properly? Isnt that what the app is supposed to do?
For the first time I have a phone with different LED colors I would like to set them up right. iPhone users are on their like 5 version and still no LED notifications lol
- 07-10-2012, 09:42 PM #15
This is weird behavior. Wonder why (if) it was designed like that?
- 07-10-2012, 11:38 PM #16
- 07-11-2012, 07:07 AM #17
- 07-11-2012, 09:31 AM #18
- 07-11-2012, 11:44 AM #19
Solid for me too, will await update?
- 07-11-2012, 11:11 PM #20
Seems like it blinks for standard apps but solid for 3rd party apps?
Sent from my SCH-I535 using Android Central Forums - 07-11-2012, 11:34 PM #21
- 07-13-2012, 01:01 PM #22
I concur. It was lighting solid when I had the third party apps on the phone, but after I took them off it went back to flashing.
- 07-13-2012, 05:08 PM #23
- 07-15-2012, 03:18 PM #24
I have the same issue. Whatsapp causes solids blue LED, google+ cause a solid greenish LED, google voice causes a solid purple LED, gmail and texts through the stock messaging system blink blue. I only noticed this in the last couple of days, was wondering if it happened after I installed swype beta, but could've been that way the whole time and I just didn't notice until today.
On an aside, there seem to be some issues with google+ instant upload too. Notifications don't always go away. - 07-15-2012, 10:56 PM #25
Haven't had an issue - texts, emails, and gmail all glow blue when the screen is off, and my Kik messenger gives a solid green when the screen is off...
Reply
