Results 1 to 4 of 4
    Default SD Card Problems
    Received my S3 Friday. Works great. However, it will not move apps to SD Card no matter what I have used or tried. Reads card fine (music, movies, etc.)Formatted card using the G3. Anyone else having this issue?
  2. #2
    Default Re: SD Card Problems
    Unless you root, ICS will not let you move apps to an SD card.
  3. #3
    Default
    Quote Originally Posted by mg2380 View Post
    Seems like we're going backwards with ics if that's the true case
    Sent from my SCH-I535 using Android Central Forums
    not good news. I did buy a standalone app for my Xoom (ICS) that does write to the SD card. Sounds like I'll have to wait for another developer to provide the same path. Thanks for the feedback.
